Introduction
If your camera doesn't work and it needs to be replaced, this guide will come in handy.
On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
Using the Phillips #00 screwdriver, unscrew the 4 screws holding the silver casing down.
Use the spudger to lift the logic board from its socket. Remove it from the rest of the phone.
Slide the flat end of the spudger between the printed circuit board and metal holder.
Pop the camera up
