Palm IIIx Motherboard Assembly Replacement
  1. Palm IIIx Motherboard Assembly Replacement, Battery: step 1, image 1 of 1
    • Place the Palm IIIx face down on a flat surface.
  2. Palm IIIx Motherboard Assembly Replacement: step 2, image 1 of 1
    • Push down and lift up the battery cover to remove it.
  3. Palm IIIx Motherboard Assembly Replacement: step 3, image 1 of 1
    • Remove the old batteries one at a time.
  4. Palm IIIx Motherboard Assembly Replacement, Motherboard Assembly: step 4, image 1 of 1
    • Using a Phillips #00 screwdriver, remove the four screws that hold the back cover in place.
  5. Palm IIIx Motherboard Assembly Replacement: step 5, image 1 of 1
    • Hold the device on its side, positioning your hands as shown.
    • Remove the back cover by pushing in with your thumbs and pulling outward with the rest of your fingers.
  6. Palm IIIx Motherboard Assembly Replacement: step 6, image 1 of 1
    • Hold the screen and front cover on its side, facing the screen inward as shown.
    • Position your hands so that you can push the screen outward with your thumbs.
    • Remove the screen by pushing outward with your thumbs. Use your index fingers to hold the front cover in place.
  7. Palm IIIx Motherboard Assembly Replacement: step 7, image 1 of 2 Palm IIIx Motherboard Assembly Replacement: step 7, image 2 of 2
    • Position the device with the screen facing down.
    • Locate the white ribbon wire on the left hand side of the device.
    • On either side of the ribbon wire are two white clasps. Gently push the two clasps away from the board (to the left).
  8. Palm IIIx Motherboard Assembly Replacement: step 8, image 1 of 1
    • Detach the ribbon wire by gently pulling it out of its connector.
  9. Palm IIIx Motherboard Assembly Replacement: step 9, image 1 of 1
    • Separate the motherboard from the screen.
  10. Palm IIIx Motherboard Assembly Replacement: step 10, image 1 of 1
    • Now the motherboard assembly can be replaced successfully.
Ben Johnson
22 Reputation
1 Guide authored
Cal Poly, Team 14-43, Regan Winter 2010 Member of Cal Poly, Team 14-43, Regan Winter 2010
CPSU-REGAN-W10S14G43
4 Members
4 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 3,087
