Introduction
Follow this guide to remove and replace the screen on your Palm IIIc.
Keep track of all pieces removed from the device.
Gently pull off the device cover. The cover snaps on and off easily where the cover attaches to the Palm IIIc device
Using a Phillips head screwdriver, take out the four screws on the back of the device. You may have to pull them out with your hands once they are unscrewed.
Using a spudger, carefully pry open the front and back covers along the side seam.
On the back of the motherboard use tweezers to pull up the ZIF connector which looks like a brown plastic tab.
Once the ZIF connector is unattached, remove the clear screen cover.
Gently pull the black clips on the inside case to detach the motherboard from the device. Pull the motherboard out towards the bottom left corner.
