Installing Palm IIIc Button Pad
  1. Installing Palm IIIc Button Pad, Removing broken LCD screen: step 1, image 1 of 1
    • Keep track of all pieces removed from the device.
    • Gently pull off the device cover. The cover snaps on and off easily where the cover attaches to the Palm IIIc device
  2. Installing Palm IIIc Button Pad: step 2, image 1 of 1
    • Using a Phillips head screwdriver, take out the four screws on the back of the device. You may have to pull them out with your hands once they are unscrewed.
    • There will be two long screws and two short screws. The long screws come from the top of the device, and the short screws come from the bottom of the device.
  3. Installing Palm IIIc Button Pad, Remove the Front Cover: step 3, image 1 of 1
    • Lay Palm IIIc face-up and remove the front cover.
    • Do this firmly but not with too much force so as to not break or disturb anything you're not supposed to.
  4. Installing Palm IIIc Button Pad, Button Pad: step 4, image 1 of 2 Installing Palm IIIc Button Pad, Button Pad: step 4, image 2 of 2
    • Using a prying tool, carefully pop button pad out of the cover.
  5. Installing Palm IIIc Button Pad: step 5, image 1 of 1
    • Insert the new button pad where the old one used to be.
Paulina Trujillo
265 Reputation
8 Guides authored
Cal Poly, Team 20-69, Walters Spring 2011 Member of Cal Poly, Team 20-69, Walters Spring 2011
CPSU-WALTERS-S11S20G69
5 Members
8 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 1,361
