Replacing Palm Centro Speakers
  1. Replacing Palm Centro Speakers, Disassembling Palm Centro Battery: step 1, image 1 of 2 Replacing Palm Centro Speakers, Disassembling Palm Centro Battery: step 1, image 2 of 2
    • Press and slide open the battery cover.
  2. Replacing Palm Centro Speakers: step 2, image 1 of 1
    • Caution: Turn cell phone off before removing battery!
    • Press battery to the right.
    • Then lift up battery pack to remove.
  3. Replacing Palm Centro Speakers: step 3, image 1 of 1
    • Phone with battery removed
  4. Replacing Palm Centro Speakers, Back Housing: step 4, image 1 of 1
    • Remove the touchpad pen from the top left corner on the back to reveal the last of 6 screws to be removed.
  5. Replacing Palm Centro Speakers: step 5, image 1 of 1
    • Lift the rubber cap at the top right to reveal the sixth screw.
    • Caution: There is a small Palm sticker under the rubber cap. Tampering with or removing this sticker will void your warranty!
    • Remove the six screws using the T5 Torx screwdriver.
  6. Replacing Palm Centro Speakers: step 6, image 1 of 2 Replacing Palm Centro Speakers: step 6, image 2 of 2
    • Remove the SIM card so housing can be separated.
  7. Replacing Palm Centro Speakers: step 7, image 1 of 2 Replacing Palm Centro Speakers: step 7, image 2 of 2
    • Use a plastic pry tool to separate the bottom of the case to remove the small plastic insert.
  8. Replacing Palm Centro Speakers: step 8, image 1 of 2 Replacing Palm Centro Speakers: step 8, image 2 of 2
    • Remove the small plastic insert at the bottom of the phone.
  9. Replacing Palm Centro Speakers: step 9, image 1 of 2 Replacing Palm Centro Speakers: step 9, image 2 of 2
    • Continue with plastic pry tool all the way around the phone to remove the back housing.
  10. Replacing Palm Centro Speakers, Logic Board: step 10, image 1 of 1
    • Carefully peel back the tape holding the speaker (left) and keyboard (right) connection tabs in place.
  11. Replacing Palm Centro Speakers: step 11, image 1 of 1
    • Using the plastic prying tool, lift the tabs and carefully pull the contact connections out on both sides.
    • Be very careful, these electronics are delicate!
  12. Replacing Palm Centro Speakers: step 12, image 1 of 1
    • Separate the logic board from the case by lifting and pulling out the bottom.
  13. Replacing Palm Centro Speakers, Speakers: step 13, image 1 of 3 Replacing Palm Centro Speakers, Speakers: step 13, image 2 of 3 Replacing Palm Centro Speakers, Speakers: step 13, image 3 of 3
    • Pry the four plastic latches free that connect the antenna to the logic board.
    • Excessive force may damage your logic board!
    • Remove the antenna from the logic board.
  14. Replacing Palm Centro Speakers: step 14, image 1 of 1
    • The internal speaker is attached to the antenna. To remove it, pry the speaker from the antenna using the tip of your screwdriver.
    • The speaker should be placed back into its spot in the correct position. Take notice of the gold connectors
Kevin
31 Reputation
1 Guide authored
Cal Poly, Team 15-49, Garner Spring 2010 Member of Cal Poly, Team 15-49, Garner Spring 2010
CPSU-GARNER-S10S15G49
5 Members
12 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 1,485
