Installing PSP Go Trigger buttons
  1. Installing PSP Go Trigger buttons, Back Cover: step 1, image 1 of 2 Installing PSP Go Trigger buttons, Back Cover: step 1, image 2 of 2
    • Unscrew the four Phillips screws on the back of the PSP Go.
    • Rotate the PSP so you can see the top of the device.
    • Unscrew the two Phillips screws next to the volume buttons.
  2. Installing PSP Go Trigger buttons: step 2, image 1 of 2 Installing PSP Go Trigger buttons: step 2, image 2 of 2
    • Use a plastic opening tool around the perimeter of the back cover to loosen it on all sides.
    • Open the back cover by gently lifting the right side, and rotating it to the left side (as if you were opening a book).
    • Be careful not to rotate the back cover from the bottom, as you will break the plastic screw holes on top of the device.
  3. Installing PSP Go Trigger buttons, Top Cover: step 3, image 1 of 1
    • Pull the top cover upwards gently from its housing.
  4. Installing PSP Go Trigger buttons, Trigger buttons: step 4, image 1 of 1
    • The top cover will most likely come off during the repair, so might as well take it off now. Pull it upwards gently from its housing.
  5. Installing PSP Go Trigger buttons: step 5, image 1 of 1
    • The procedure is exactly the same for the left trigger button.
    • Use a plastic opening tool to gently flip up the left trigger connector.
  6. Installing PSP Go Trigger buttons: step 6, image 1 of 2 Installing PSP Go Trigger buttons: step 6, image 2 of 2
    • Unscrew the lone Phillips screw holding the trigger in place. Remove both trigger and retaining plate from the PSP Go.
    • If necessary, repeat steps 2 and 3 to remove the right trigger button.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 53
All Time: 11,476
