PSP Go Top Cover Replacement
  1. PSP Go Top Cover Replacement, Back Cover: step 1, image 1 of 2 PSP Go Top Cover Replacement, Back Cover: step 1, image 2 of 2
    • Unscrew the four Phillips screws on the back of the PSP Go.
    • Rotate the PSP so you can see the top of the device.
    • Unscrew the two Phillips screws next to the volume buttons.
  2. PSP Go Top Cover Replacement: step 2, image 1 of 2 PSP Go Top Cover Replacement: step 2, image 2 of 2
    • Use a plastic opening tool around the perimeter of the back cover to loosen it on all sides.
    • Open the back cover by gently lifting the right side, and rotating it to the left side (as if you were opening a book).
    • Be careful not to rotate the back cover from the bottom, as you will break the plastic screw holes on top of the device.
  3. PSP Go Top Cover Replacement, Top Cover: step 3, image 1 of 1
    • Pull the top cover upwards gently from its housing.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 29
All Time: 5,962
