Installing PSP Go Bottom Plate
  1. Installing PSP Go Bottom Plate, Back Cover: step 1, image 1 of 2 Installing PSP Go Bottom Plate, Back Cover: step 1, image 2 of 2
    • Unscrew the four Phillips screws on the back of the PSP Go.
    • Rotate the PSP so you can see the top of the device.
    • Unscrew the two Phillips screws next to the volume buttons.
  2. Installing PSP Go Bottom Plate: step 2, image 1 of 2 Installing PSP Go Bottom Plate: step 2, image 2 of 2
    • Use a plastic opening tool around the perimeter of the back cover to loosen it on all sides.
    • Open the back cover by gently lifting the right side, and rotating it to the left side (as if you were opening a book).
    • Be careful not to rotate the back cover from the bottom, as you will break the plastic screw holes on top of the device.
  3. Installing PSP Go Bottom Plate, Top Cover: step 3, image 1 of 1
    • Pull the top cover upwards gently from its housing.
  4. Installing PSP Go Bottom Plate, Bottom Plate: step 4, image 1 of 2 Installing PSP Go Bottom Plate, Bottom Plate: step 4, image 2 of 2
    • Remove the two Phillips screws holding the bottom plate.
    • Gently lift the bottom plate away from the device.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 25
All Time: 7,236
