PSP 300x D-Pad Replacement
  1. PSP 300x D-Pad Replacement, Battery: step 1, image 1 of 3 PSP 300x D-Pad Replacement, Battery: step 1, image 2 of 3 PSP 300x D-Pad Replacement, Battery: step 1, image 3 of 3
    • Place the PSP face down and locate the battery cover on the left side of the device.
    • Lift and remove the battery cover to reveal the battery.
    • Remove the battery.
  2. PSP 300x D-Pad Replacement, Casing: step 2, image 1 of 1
    • Peel back the warranty sticker that is behind the battery with a spudger or your fingernail.
  3. PSP 300x D-Pad Replacement: step 3, image 1 of 2 PSP 300x D-Pad Replacement: step 3, image 2 of 2
    • Unscrew all four screws from the back of the PSP with the Phillips #00 Screwdriver.
    • Two are located behind the battery's warranty sticker.
    • Two are located on the right side of the PSP.
  4. PSP 300x D-Pad Replacement: step 4, image 1 of 1
    • Next, unscrew the two screws located at the top of the PSP.
  5. PSP 300x D-Pad Replacement: step 5, image 1 of 1
    • Then, remove the single screw from the bottom edge of the PSP (which is positioned next to the barcode).
  6. PSP 300x D-Pad Replacement: step 6, image 1 of 2 PSP 300x D-Pad Replacement: step 6, image 2 of 2
    • Slide the spudger in between the outer casing of the PSP, beginning at the "R" shoulder button, and gently pry off the casing.
    • Remove the front casing completely.
  7. PSP 300x D-Pad Replacement, D-Pad: step 7, image 1 of 2 PSP 300x D-Pad Replacement, D-Pad: step 7, image 2 of 2
    • Peal up the rubber pad that is securing the D-pad buttons to the backside of the front casing.
    • Remove the D-pad and the rubber piece.
mbnewsom
3,103 Reputation
11 Guides authored
Past 24 Hours: 1
Past 7 Days: 27
Past 30 Days: 121
All Time: 9,384
