Shop the Holiday Gift Guide
PS5 DualSense Edge Controller Stick Module Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
10
Past 30 Days:
24
All Time:
147
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 4 - 7 minutes
Difficulty: Easy
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Introduction
Go to step 1 ↓
The PS5 DualSense Edge (Pro) Controller is packed with cutting-edge features like adaptive triggers and advanced haptic feedback, delivering an immersive gaming experience. Though, even the most high-tech gear isn't immune to wear and tear. One of the most common issues gamers face is stick drift, when the analog stick starts moving on its own or responds inaccurately, throwing off your aim or camera during gameplay.
Stick drift can result from everyday use, dust buildup, or natural wear of the stick module. Unfortunately, many users assume the only solution is to replace the entire controller, an expensive and wasteful choice.
The good news? You don't need to be a pro to fix stick drift. Replacing the stick module is easier than you might think, and doing it yourself can save money, extend the life of your controller, and reduce e-waste.
This step-by-step guide will walk you through the repair process so you can get back to gaming with precision, without breaking the bank or adding to the landfill. Let’s get started!
    1. PS5 DualSense Edge Controller Stick Module Replacement, Stick Module: step 1, image 1 of 3 PS5 DualSense Edge Controller Stick Module Replacement, Stick Module: step 1, image 2 of 3 PS5 DualSense Edge Controller Stick Module Replacement, Stick Module: step 1, image 3 of 3
      • Make sure your controller is turned off and unplugged from any cables or devices.
      • Working on a powered controller can cause damage or short circuits. Always make sure to power it down first!
      • Have your supplies ready: your controller, stick module unit, and a soft surface to prevent any damage while following these steps.
      Ask FixBot
    2. PS5 DualSense Edge Controller Stick Module Replacement: step 2, image 1 of 2 PS5 DualSense Edge Controller Stick Module Replacement: step 2, image 2 of 2
      • Turn the controller over so the back is facing you.
      • Near the bottom, find the small switch labeled "Release" and slide it.
      • The front plate should come off.
      • Do not pry or bend the faceplate; it is designed to come off easily with the release switch.
      Ask FixBot
    3. PS5 DualSense Edge Controller Stick Module Replacement: step 3, image 1 of 2 PS5 DualSense Edge Controller Stick Module Replacement: step 3, image 2 of 2
      • Identify the analog stick module you'll want to replace.
      • Each module is secured with a silver latch tab.
      • Gently pull up on the wide part of the latch tab until you hear two clicks.
      Ask FixBot
    4. PS5 DualSense Edge Controller Stick Module Replacement: step 4, image 1 of 2 PS5 DualSense Edge Controller Stick Module Replacement: step 4, image 2 of 2
      • Release and remove the module.
      • The module will slide forward, indicating the disconnection from the controller, and is ready to be removed.
      • Carefully pull it out.
      Ask FixBot
    5. PS5 DualSense Edge Controller Stick Module Replacement: step 5, image 1 of 3 PS5 DualSense Edge Controller Stick Module Replacement: step 5, image 2 of 3 PS5 DualSense Edge Controller Stick Module Replacement: step 5, image 3 of 3
      • Now, align the new module with the same port.
      • Slide it in until it clicks into place.
      • Press the sliver latch tab back down to lock it in securely.
      • Make sure the module is placed in properly and locked; loose parts may not let the controller function correctly.
      Ask FixBot
    6. PS5 DualSense Edge Controller Stick Module Replacement: step 6, image 1 of 3 PS5 DualSense Edge Controller Stick Module Replacement: step 6, image 2 of 3 PS5 DualSense Edge Controller Stick Module Replacement: step 6, image 3 of 3
      • Line up the faceplate with the front of the controller.
      • Ensure that the top clips of the faceplate are aligned with the holes above the stick modules before snapping it in place
      • Press it back on until it snaps firmly into place.
      Ask FixBot
    7. PS5 DualSense Edge Controller Stick Module Replacement: step 7, image 1 of 1
      • Power your controller back on.
      • Connect it to your PS5 or PC.
      • Test the new analog stick in a game or through the system settings menu.
      • Ensure that it moves smoothly in all directions without any stick drift or other performance issues.
      Ask FixBot
That is it! By replacing your stick module yourself, you have saved money, cut down on repair wait times, and kept a perfectly good controller out of the trash. At first, it might seem intimidating but taking the time to learn and fix something on your own is seriously rewarding. Plus, the more we repair instead of replace, the closer we are to having less e-waste.
Thanks for following along with our guide, we hope we were able to make this process clear and doable.
Author
with
Alex Melgar
145 Reputation
1 Guide authored
UC Davis, Team 1-5, Whithaus Spring 2025 Member of UC Davis, Team 1-5, Whithaus Spring 2025
UCD-WHITHAUS-S25S1G5
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 24
All Time: 147
