MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal
  1. MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Remove Back Panel Screws: step 1, image 1 of 2 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Remove Back Panel Screws: step 1, image 2 of 2
    • To begin, we will need to remove 6 total screws
    • 2x 6.9mm Pentalobe P5
    • 2x 5.5mm Pentalobe P5
    • 2x 3.5mm Pentalobe P5
    Ask FixBot
  2. MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Prop Up Back Panel: step 2, image 1 of 2 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Prop Up Back Panel: step 2, image 2 of 2
    Tool used on this step:
    Heavy-Duty Suction Cups (Pair)
    $16.95
    Buy
    • After the screws are removed, grab a suction cup. We used iFixit's Heavy Duty Suction cup.
    • Place the suction cup towards the bottom of the Macbook
    • Pull up on the suction cup; Creating about 0.15in worth of space from the panel and the Macbook.
    • Don't lift it any higher, as it could damage inside compenents
    Ask FixBot
  3. MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Prop Up Back Panel: step 3, image 1 of 3 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Prop Up Back Panel: step 3, image 2 of 3 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Prop Up Back Panel: step 3, image 3 of 3
    iFixit Opening Picks (Set of 6)
    $4.95
    Buy
    • While creating the gap between the Macbook and the back panel, insert an opening pick into the gap about 0.2in.
    • Don't insert the pick further, as this could cause internal damage
    • Move the pick towards the left side of the Macbook and around the corner edge.
    • Bring the pick up towards the top of the Macbook
    • Once you reach about the middle of the Macbook, you should hear a click. This is good! You have now unhooked part of the back panel.
    Ask FixBot
  4. MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal: step 4, image 1 of 2 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal: step 4, image 2 of 2
    • Repeat Step 3 but on the right side of the Macbook
    • Once done, don't remove the back panel just yet. It is still attached to the Macbook
    Ask FixBot
  5. MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Prop Up Back Panel: step 5, image 1 of 2 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Prop Up Back Panel: step 5, image 2 of 2
    • Insert your fingers in-between the back panel and Macbook and pry upwards to unhook the middle hook keeping the back panel connected to the Macbook
    • Don't attempt to remove the back panel yet. It is still connected to the Macbook
    Ask FixBot
  6. MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing Back Panel: step 6, image 1 of 2 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing Back Panel: step 6, image 2 of 2
    • Grip the back panel with one hand
    • Grip the Macbook with the other hand
    • And pull the left side of the back panel AWAY from the HINGE side of the Macbook
    • This will require a lot of force. Don't be afraid to pull hard while keeping the Macbook steady and in position.
    • Repeat this with the right side of the Macbook
    • Once pulled from the hinge area, you may now remove the back panel and place it out of the way.
    Ask FixBot
  7. MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing Battery Connector Cover: step 7, image 1 of 3 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing Battery Connector Cover: step 7, image 2 of 3 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing Battery Connector Cover: step 7, image 3 of 3
    $3.99
    Buy
    • Locate the battery connector cover
    • Take a pair of tweezers and gently remove the plastic cover from the Logic Board
    • Be careful not to pull on any flex cables
    Ask FixBot
  8. MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Disconnecting Battery: step 8, image 1 of 3 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Disconnecting Battery: step 8, image 2 of 3 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Disconnecting Battery: step 8, image 3 of 3
    $3.99
    Buy
    • Locate the small flex cable covering the battery terminal
    • Take a pair of tweezers in one hand and pull up on the plastic flap
    • Take the hook end of a Halberd Spudger in the other hand and gently pry up the retaining flap on the battery cable ZIF socket
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Make sure to use gentle force as this shouldn't require a lot of force. If excessive force is used, you could break the flex cable.
    Ask FixBot
  9. MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Disconnecting Battery: step 9, image 1 of 1
    $3.99
    Buy
    • Take your tweezers and pull on the plastic cover away from the ZIF socket to remove the flex cable from its socket
    Ask FixBot
  10. MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Disconnecting the Battery: step 10, image 1 of 3 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Disconnecting the Battery: step 10, image 2 of 3 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Disconnecting the Battery: step 10, image 3 of 3
    Spudger
    $3.99
    Buy
    • Remove the 3.8mm Torx T5 screw from the battery connector
    • Take the flat end of a spudger and pry up the battery connector to a 90° angle
    • Prying it this far away from the contact pads ensures there won't be any contact between the Logic Board and the battery
    • Be mindful of the battery connector. If you flip the Macbook and lay it down on the table, you could damage the battery connector
    Ask FixBot
  11. MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing Left Hinge Cover: step 11, image 1 of 3 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing Left Hinge Cover: step 11, image 2 of 3 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing Left Hinge Cover: step 11, image 3 of 3
    $3.99
    Buy
    • Locate the left hinge cover
    • Remove 2x 2mm Torx T3 screws securing the hinge cover to the Macbook
    • Take a pair of tweezers and remove the hinge cover
    Ask FixBot
  12. MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing Right Hinge Cover: step 12, image 1 of 3 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing Right Hinge Cover: step 12, image 2 of 3 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing Right Hinge Cover: step 12, image 3 of 3
    $3.99
    Buy
    • Locate the right hinge cover
    Ask FixBot
  13. MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing LCD Flex Cable Brackets: step 13, image 1 of 3 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing LCD Flex Cable Brackets: step 13, image 2 of 3 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing LCD Flex Cable Brackets: step 13, image 3 of 3
    $3.99
    Buy
    • Locate your LCD flex cable towards the top of the Macbook
    • Locate the bottom cover plate
    • Remove 2x 3.2mm Torx T3 screws securing the bottom cover plate to the MacBook
    • Take a pair of tweezers and remove the brackets
    Ask FixBot
  14. MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing LCD Flex Cable Cover Plates: step 14, image 1 of 2 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing LCD Flex Cable Cover Plates: step 14, image 2 of 2
    $3.99
    Buy
    • Locate the top cover plate of the LCD flex cable
    • Remove 2x 1.8mm Torx T3 screws securing the top cover plate to the Macbook
    • Take a pair of tweezers and remove the now free cover plate
    Ask FixBot
  15. MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Disconnecting LCD Flex Cable: step 15, image 1 of 3 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Disconnecting LCD Flex Cable: step 15, image 2 of 3 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Disconnecting LCD Flex Cable: step 15, image 3 of 3
    Spudger
    $3.99
    Buy
    • Take the flat end of a spudger and gently pry up the LCD flex cable from its port
    • Make sure not to pry the socket itself
    • Lift LCD flex cable up and away from the Macbook
    Ask FixBot
  16. MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing Left LCD Spring Screws: step 16, image 1 of 2 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing Left LCD Spring Screws: step 16, image 2 of 2
    • Locate the left LCD screen spring
    • Remove 2x 4.1mm Torx T3 screws securing the spring to the MacBook
    Ask FixBot
  17. MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing Right LCD Spring Screws: step 17, image 1 of 2 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing Right LCD Spring Screws: step 17, image 2 of 2
    • Locate the right LCD screen spring
    Ask FixBot
  18. MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Disconnecting Antenna From Logic Board: step 18, image 1 of 3 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Disconnecting Antenna From Logic Board: step 18, image 2 of 3 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Disconnecting Antenna From Logic Board: step 18, image 3 of 3
    $3.99
    Buy
    • Locate antenna connector cover
    • Take a pair of tweezers and gently pry up the cover from the Logic Board
    • Be careful not to pry anything but the plastic cover
    • Remove 1x 3.9mm Torx T5 screw securing the antenna cables to the MacBook
    • Take the flat end of a spudger and gently pry up the antenna cables from their sockets
    • Be careful not to pry up the socket itself
    Ask FixBot
  19. MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing Antenna Screws: step 19, image 1 of 3 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing Antenna Screws: step 19, image 2 of 3 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing Antenna Screws: step 19, image 3 of 3
    • Locate the antenna towards the top of the Macbook
    • Remove 12x 1.2mm Pentalobe P2 screws securing the antenna to the MacBook
    Ask FixBot
  20. MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing LCD Board Screws: step 20, image 1 of 3 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing LCD Board Screws: step 20, image 2 of 3 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing LCD Board Screws: step 20, image 3 of 3
    • Locate the LCD board towards the top of the Macbook
    • Remove 4x 3.4mm Torx T5 screws securing the LCD board to the MacBook and to the antenna
    Ask FixBot
  21. MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing Antenna from Macbook: step 21, image 1 of 1
    • You should now be able to remove the antenna from the Macbook.
    • Gently pry & pull away the antenna cable from the Macbook while routing it's cable through their hole. Take care here, as the antenna sockets can be ripped from the board easily.
    • You can straighten out the cables to make it easier or simply twist and turn the antenna to maneuver the cables out of their hole.
    Ask FixBot
  22. MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing Left Hinge Screws: step 22, image 1 of 2 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing Left Hinge Screws: step 22, image 2 of 2
    • Locate the left LCD screen hinge
    • Remove 2x 4.5mm Torx T9 screws that secure the hinge to the MacBook
    • Leave 1 screw to make removing the LCD screen easier
    Ask FixBot
  23. MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing Right Hinge Screws: step 23, image 1 of 2 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing Right Hinge Screws: step 23, image 2 of 2
    • Locate the right LCD screen hinge
    Ask FixBot
  24. MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing LCD Screen: step 24, image 1 of 3 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing LCD Screen: step 24, image 2 of 3 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing LCD Screen: step 24, image 3 of 3
    • Place MacBook at the edge of your work bench and let the screen overhang
    • Locate and remove the remaining 2x 4.5mm Torx T9 screws securing the 2 hinges to the MacBook
    • The MacBook display will now freely dangle on the edge of the table. It won't fall due to the hinges being inside a divot in the MacBook
    Ask FixBot
  25. MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing LCD Screen: step 25, image 1 of 2 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing LCD Screen: step 25, image 2 of 2
    • Bend the LCD screen slightly towards you
    • Gently pry up the LCD screen from the Macbook, while guiding the hinges out of their divots
    • During reassembly make sure to place the hinges into the divots. Once in the divots, you can then screw 1 screw back into each hinge and then shut the Macbook. This will allow you to properly arrange and align the LCD hinges
    Ask FixBot
  26. MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing Power Button Bracket: step 26, image 1 of 3 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing Power Button Bracket: step 26, image 2 of 3 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing Power Button Bracket: step 26, image 3 of 3
    $3.99
    Buy
    • Locate the power button flex cable bracket towards the top left of the MacBook
    • Remove 2x screws securing the bracket to the MacBook
    • 1x 5mm Torx T3 Screw
    • 1x 1.4mm Torx T3 Screw
    • During Reassembly: You may want to use this screw to screw in the logicboard standoff underneath.
    • Make sure to grab and pickup ONLY the bracket.
    Ask FixBot
  27. MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing Trackpad Cable Bracket: step 27, image 1 of 3 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing Trackpad Cable Bracket: step 27, image 2 of 3 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing Trackpad Cable Bracket: step 27, image 3 of 3
    $3.99
    Buy
    • Locate the trackpad's flex cable bracket towards the middle of the Macbook
    • Remove 2x 1.9mm Torx T5 screws securing the bracket to the Macbook
    • Then take a pair of tweezers and remove the bracket
    Ask FixBot
  28. MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Disconnecting Trackpad From Logic Board: step 28, image 1 of 3 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Disconnecting Trackpad From Logic Board: step 28, image 2 of 3 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Disconnecting Trackpad From Logic Board: step 28, image 3 of 3
    Spudger
    $3.99
    Buy
    • Using the flat end of a spudger gently lift the connector from its socket
    • Make sure to not pry the socket itself
    • It might make it easier if you pry it up a little on all 3 sides
    Ask FixBot
  29. MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing Right Speaker Flex Cable Bracket: step 29, image 1 of 3 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing Right Speaker Flex Cable Bracket: step 29, image 2 of 3 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing Right Speaker Flex Cable Bracket: step 29, image 3 of 3
    $3.99
    Buy
    • Locate the right speaker flex cable bracket
    • Remove 2x screws securing the bracket down to the Logic Board
    • 1x 3.7mm Torx T5
    • 1x 2.6mm Torx T5
    • Make sure to not grab the flex cable while removing the bracket
    Ask FixBot
  30. MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Disconnecting Right Speaker From Logic Board: step 30, image 1 of 2 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Disconnecting Right Speaker From Logic Board: step 30, image 2 of 2
    Spudger
    $3.99
    Buy
    • Take the flat end of a spudger and carefully pry up the flex cable from its socket
    • Be careful not to pry up on the socket itself
    • There are sensitive filters near the socket. Make sure to be ultra careful not to knock one of those "microscopic" filters off.
    Ask FixBot
  31. MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing Left Speaker & Touch Bar Flex Cable Bracket: step 31, image 1 of 3 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing Left Speaker & Touch Bar Flex Cable Bracket: step 31, image 2 of 3 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing Left Speaker & Touch Bar Flex Cable Bracket: step 31, image 3 of 3
    $3.99
    Buy
    • Locate the left speaker and touch bar bracket
    • Remove 3x 1.4mm Torx T3 screws from the bracket
    • Be sure not to grab any of the flex cables while removing the bracket
    Ask FixBot
  32. MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Disconnecting Flex Cables: step 32, image 1 of 3 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Disconnecting Flex Cables: step 32, image 2 of 3 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Disconnecting Flex Cables: step 32, image 3 of 3
    Spudger
    $3.99
    Buy
    • Take the flat-end of a spudger and gently pry up all 3 flex cables from their sockets
    Ask FixBot
  33. MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Disconnecting More Flex Cables: step 33, image 1 of 3 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Disconnecting More Flex Cables: step 33, image 2 of 3 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Disconnecting More Flex Cables: step 33, image 3 of 3
    $3.99
    Buy
    • Locate 8x flex cables connected the logic board
    • For each flex cable, pull up on their plastic flap with a pair of tweezers
    • Take the hook end of a Halberd Spudger and gently pry up the retaining flap on the ZIF socket of each cable
    • Take your tweezers and pull on the plastic cover to pull each cable away from the ZIF socket to remove the flex cable from it's socket
    • If any of the plastic flaps break off don't worry! You can use a combination of your spudger and tweezers to gently pull out the flex cable from it's respective socket
    Ask FixBot
  34. MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing Logic Board Screws: step 34, image 1 of 2 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing Logic Board Screws: step 34, image 2 of 2
    • Locate and remove 5x Logic Board Screws
    • 3x 3.4mm Torx T5 screws
    • 1x 3.6mm Torx T5 stepped screw
    • 1x 3.3mm hex standoff (3mm drive)
    • During Reassembly: It may be difficult to screw the top left logic board standoff back in. If you are finding it hard to do this, take the 1.4mm screw that we removed to remove the power button bracket and screw it into the top left logic board standoff. Afterwards, take the now "cyborg" screw and screw it into the logic board.
    • Don't forget to remove the 1.4mm screw from the logic board standoff during reassembly
    Ask FixBot
  35. MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing Logic Board From Macbook: step 35, image 1 of 1
    Halberd Spudger
    $2.99
    Buy
    • Take the hook end of your Halberd Spudger and gently pry up the top left corner of the logic board
    • Now remove the logic board from the Macbook
    • Be careful not to rip or tear any flex cables while removing or placing down the logic board
    • During reassembly, make sure to take your spudger while placing the logic board down and move any flex cable away from being squashed, tore, or ripped.
    Ask FixBot
  36. MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing Touchbar Screws: step 36, image 1 of 3 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing Touchbar Screws: step 36, image 2 of 3 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing Touchbar Screws: step 36, image 3 of 3
    $3.99
    Buy
    • Locate the touchbar flex cable mess towards the top right of the Macbook
    • You will be removing a total of 3 screws to release this cabled mess from the frame
    • 2x 2.4mm
    • One of these are "hidden" by a small pad. Take a pair of tweezers and remove this pad to access the screw head
    • 1x 1.7mm
    Ask FixBot
  37. MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing Touchbar Flex Cable Brackets: step 37, image 1 of 2 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Removing Touchbar Flex Cable Brackets: step 37, image 2 of 2
    • These brackets that keep the cabled mess down and attached to the frame are adhered to the cabling
    • Remove these brackets from the flex cabling mess
    • TIP: Be mindful of how the brackets are positioned in relation to the cables and frame. Take pictures to reference. Without these brackets, the cables will be free inside the frame (which is not good).
    • There are also little wraps of plastic holding different parts of the cabling together. Go ahead and CAREFULLY remove these as we won't need them during reassembly and we do need them removed to completely remove the touchbar
    • Follow this guide to properly install the new touchbar
    Ask FixBot
  38. MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Methods of Removing The Actual Touchbar: step 38, image 1 of 1
    iFixit Adhesive Remover
    $19.99
    Buy
    • There are 2 methods that we can take towards removing this annoying touchbar. We went ahead and performed what we thing is the harder method.
    • Method 1: Take 2 tweezers or handles and wrap very thin wire around them. Then pull the wire underneath the touchbar LCD gently while being careful not to damage the keyboard
    • This method keeps the frame underneath the touchbar from scratching a whole bunch, eliminates the possibility of the keyboard keys "melting" from the Adhesive Remover, and allows you to possibly reuse the touchbar.
    • Method 2: What we did. Remove the touchbar digitizer first by prying it up and off the touchbar LCD. Then use a combination Adhesive Remover and a Technician's Razor Set to remove the touchbar LCD.
    • This method takes longer and more patience. However, we didn't have wire at our disposal and we weren't needing to reuse the touchbar
    Ask FixBot
  39. MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Our Method of Removing This Specific Touchbar: step 39, image 1 of 3 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Our Method of Removing This Specific Touchbar: step 39, image 2 of 3 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Our Method of Removing This Specific Touchbar: step 39, image 3 of 3
    Halberd Spudger
    $2.99
    Buy
    • Take a Halberd Spudger and insert the knife end right underneath the plastic of the digitizer
    • Run the Halberd Spudger along the edge of the touchbar digitizer
    • The digitizer should separate surprisingly easy.
    • Feed the Touchbar digitizer cable through the hole and remove the digitizer
    Ask FixBot
  40. MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Prying Up The LCD of The Touchbar: step 40, image 1 of 2 MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal, Prying Up The LCD of The Touchbar: step 40, image 2 of 2
    $14.99
    Buy
    • Take a technician's knife and start prying away the LCD of the touchbar.
    • Use adhesive remover from time to time to help loosen the adhesive
    • Don't let any of the adhesive remover touch the keyboard keys or any plastic for that matter. It will melt and eat away at any plastic it comes in-contact with
    Ask FixBot
To reassemble your device, follow these instructions in reverse order. Follow this guide to reinstall the new touchbar properly.
We here at Smart Cloud hope your project goes smoothly and without a hitch. However, things happen and we want to make sure you know we are here to help if needed. You may contact us if needed as we can provide support or repair options per request. Good luck and have fun.
4 other people completed this guide.
Thomas Kirschbaum
1,878 Reputation
3 Guides authored
Smart Cloud LLC Member of Smart Cloud LLC
Business
1 Member
9 Guides authored
3 Guide Comments
Bonjour, excellent tuto. Bien réalisé grâce aux outils MAKO de ifixit.
Etape 31, il faut utiliser T5. Les 3 vis n'ont pas toutes la même longueur.
J'ai cassé un connecteur sur la carte : est ce que je peux mettre de la colle chaude pour tenir la nappe ?
Encore merci pour cette précieuse aide
Nize - Reply Share
Hello, What is the connector of the photo 20210430_142817.jpg? I broke it :-((. Since the reassembly, the microphone and the backlight of the keyboard do not work : how to fix them? in advance thank you for your help - Best regards Nize
Nize - Reply Share
This guide saved the data on a 2020 M1 MacBook Pro 2hrs after falling into a bathtub. Thank you!
MotorMac - Reply Share
Past 24 Hours: 6
Past 7 Days: 32
Past 30 Days: 185
All Time: 7,294
