PS4 Dualshock 4 trigger reassembly
  1. PS4 Dualshock 4 trigger reassembly, Preparing the triggers: step 1, image 1 of 2 PS4 Dualshock 4 trigger reassembly, Preparing the triggers: step 1, image 2 of 2
    • Remove these two triggers and springs from the backplate.
    • Find which trigger goes on which side and put the springs in the trigger part facing towards the inside of the controller.
  2. PS4 Dualshock 4 trigger reassembly, Attaching the triggers.: step 2, image 1 of 2 PS4 Dualshock 4 trigger reassembly, Attaching the triggers.: step 2, image 2 of 2
    • On these two clips...
    • Push down the trigger until it clicks on both sides.
    • Make sure that the one spring part is inside the rail (marked cyan) and the other outside the whole assembly (green).
  3. PS4 Dualshock 4 trigger reassembly, Connecting the light bar: step 3, image 1 of 1
    • Connect the light bar cable using your fingers. Make sure it is fully pushed down and that is plugged in the right way.
  4. PS4 Dualshock 4 trigger reassembly, Closing the cover: step 4, image 1 of 2 PS4 Dualshock 4 trigger reassembly, Closing the cover: step 4, image 2 of 2
    • close the cover starting from the side of the triggers. Don't worry if it's a bit hard to do so, but be careful so you don't break the plastic between the trigger and the bumper.
    • Push down until it clicks everywhere.
    • Finally, screw in these four screws using a PH0 screwdriver.
Devnol
2,702 Reputation
5 Guides authored
Past 24 Hours: 10
Past 7 Days: 116
Past 30 Days: 506
All Time: 40,634
