Introduction
This is a prerequisite-only guide! This guide is part of another procedure and is not meant to be used alone.
Use a pair of tweezers to remove the sticker in the center of the back of the PS4, exposing the first screw.
Remove the two stickers at the outer edges, exposing two more screws.
Remove the three 7.2 mm-long TR8 Torx security screws on the back of the PS4.
Tool used on this step:Small Needle Nose Pliers$6.99
Use a pair of tweezers to pull the power supply cable straight out to disconnect the power supply unit from the motherboard.
Use your fingers to grab the white connector head, and wiggle or "walk" the connector out of its socket to disconnect it.
In extreme cases, you might need to use needle nose pliers to get a good grip on the connector.
