PDP Victrix Pro BFG Joysticks Replacement
Views: 3K
View statistics:
Past 24 Hours:
5
Past 7 Days:
56
Past 30 Days:
192
All Time:
3,018
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
This is the guide for replacing the joysticks on your gaming controller, the PDP Victrix Pro BFG. Whether you're customizing your controller or fixing unresponsive buttons, this guide will walk you through the process. You can use this guide to replace the buttons aswell. Be sure to check the troubleshooting section for any related issues and handle parts with care to avoid damage or injury. Let's get started!
Tools
    1. PDP Victrix Pro BFG Joysticks Replacement, Joysticks: step 1, image 1 of 1
      • Use the purple Module Swap Tool that comes with the device to remove the 4 hex screws.
      • Remove the joystick/button modules from the controller.
      Ask FixBot
    2. PDP Victrix Pro BFG Joysticks Replacement: step 2, image 1 of 2 PDP Victrix Pro BFG Joysticks Replacement: step 2, image 2 of 2
      • Turn over the joystick/button module
      • Remove four 1 mm screws using a Phillips #0 screwdriver.
      • Take the plate off with the buttons and set aside.
      • You can use this step to replace the buttons if one is damaged or if you would like to customize them.
      Ask FixBot
    3. PDP Victrix Pro BFG Joysticks Replacement: step 3, image 1 of 1
      • Using a soldering iron, desolder the the bottom part of the joystick.
      • The soldering iron is very hot; be careful to not make contact with skin.
      Ask FixBot
Jacob Gorman
197 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 56
Past 30 Days: 192
All Time: 3,018
