Introduction
P47 Headphones are one of the cheapest headphones on the market, and as they are cheap, they can easily break if dropped. If you own these headphones, accidentally dropped them, and they are not working anymore because of a loose wire, this guide can help you fix those headphones back into shape.
Set up your headphones in an accommodating space before you start the repair process.
Use the solder wire to hold the speaker wire in place if you do a solo repair.
Use the preheated iron and apply it to the solder wire, using only the tip and a small portion.
Once the solder wire melts, remove the solder iron and the unmelted solder wire. The melted solder wire will immediately cool off and stick in place.
Proceed to follow the same steps for the remaining bottom wire.
3 other people completed this guide.
