Up to 20% off select tools
This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Out of position winder
View statistics:
Past 24 Hours:
Past 7 Days:
14
Past 30 Days:
57
All Time:
305
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 seconds
Difficulty: Very easy
Community-Contributed Guide
Better Introduction
Improve this guide by completing or revising its introduction.
Parts
    1. Out of position winder, Out of position winder: step 1, image 1 of 2 Out of position winder, Out of position winder: step 1, image 2 of 2
      • The Winder is the main part of the machine responsible for the closing turns.
      • The position of the Winder must always be the same; it must be at 90 degrees, with one tab facing up and the other tab facing down. (Photo 2)
      • If the Winder is in a different position than the one shown in Photo 2, follow the next step.
      Ask FixBot
    2. Out of position winder: step 2, image 1 of 3 Out of position winder: step 2, image 2 of 3 Out of position winder: step 2, image 3 of 3
      • If the Winder is in the wrong position as shown in Photo 1, follow this step.
      • THIS ENTIRE OPERATION MUST BE PERFORMED WITH THE MACHINE TURNED OFF.
      • With the machine turned off, you can access the Winder through a gap located below the part. Then, use your index finger to reach into this gap and rotate the Winder to the correct position (Photo 2).
      • The Winder must be in the same position as in Photo 3, with one tab facing up and the other facing down.
      Ask FixBot
    3. Out of position winder: step 3, image 1 of 1
      • After that, test the machine; if it continues to have issues, contact Lacito.
      Ask FixBot
Finish Line
Author
with
Lacito
6,169 Reputation
10 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 57
All Time: 305
