Ottlite PL-0094 Lamp Switch Replacement
    1. Ottlite PL-0094 Lamp Switch Replacement, Remove Switch: step 1, image 1 of 1
      • Lay lamp on its side and remove the 2 screws between the lower and upper lamp posts. Gently pull the 2 sections apart a few inches. Slide the plastic switch cover off by sliding upwards.
      • Remove the 2 screws holding the USB port circuit board to the cover.
      • With utility blade, carefully cut the 2 plastic mounts for the touch switch circuit board and remove from cover.
      • The small flat on/off button should fall out also.
      Ask FixBot
    2. Ottlite PL-0094 Lamp Switch Replacement, Mount New Switch: step 2, image 1 of 1
      • I mounted the new switch in the location of the old switch button. There is a hole mostly there already if you just cut the remaining plastic to leave about a 3/8" hole.
      • You'll need to trim down the small plastic posts that held the switch circuit board in place.
      • The switch doesn't have a lot of threads, so you can't use thick washers. I used a 5/16" speed nut on the inside, which also helps keep the switch centered since hole is a little bit bigger than needed.
      • On the outside I used a thin plastic washer, then the nut for the switch.
      • Bend the tabs down as pictured so wiring will fit when reassembled. Tighten nut.
      Ask FixBot
    3. Ottlite PL-0094 Lamp Switch Replacement, Wiring: step 3, image 1 of 2 Ottlite PL-0094 Lamp Switch Replacement, Wiring: step 3, image 2 of 2
      • Since the the touch switch doesn't work, we discard that circuit board. Cut the 4 wires at the circuit board.
      • I soldered my wires together and covered with shrink tubing. I suppose you could use good insulated wire connectors instead.
      • Connect the 2 black wires together, the one from the USB board to the one going to the lamps.
      • Connect the red wire from the USB board to one of the switch wires. I used the red switch wire.
      • Connect the other wire from the switch to the white wire going to the lamps.
      • Screw the USB board back in place.
      Ask FixBot
      • Feed the wires back up into the lamp post holes. Fold wires so they fit inside cover as you slide the cover back in place.
      • Fit the 2 lamp posts together and install the 2 screws to hold them together.
      • Plug in, and hopefully your light now works.
      Ask FixBot
Enjoy!
KenF
139 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 32
Past 30 Days: 114
All Time: 1,778
