Shop the Holiday Gift Guide
Oster 3905 Outer Shell Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
2
Past 30 Days:
5
All Time:
332
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
Prerequisite only.
Tools
    1. Oster 3905 Outer Shell Replacement, Slot Levers: step 1, image 1 of 1
      • Firmly grip your hand around the slot lever.
      Ask FixBot
    2. Oster 3905 Outer Shell Replacement: step 2, image 1 of 1
      • Stabilize the toaster by placing your hand on top.
      Ask FixBot
    3. Oster 3905 Outer Shell Replacement: step 3, image 1 of 2 Oster 3905 Outer Shell Replacement: step 3, image 2 of 2
      • Forcefully pull the slot lever away from the toaster by keeping parallel to the table.
      Ask FixBot
    4. Oster 3905 Outer Shell Replacement: step 4, image 1 of 1
      • Both slot levers can be removed.
      Ask FixBot
    1. Oster 3905 Outer Shell Replacement, Outer Shell: step 5, image 1 of 1
      • Place the toaster upside down so the bottom is facing the ceiling.
      Ask FixBot
    2. Oster 3905 Outer Shell Replacement: step 6, image 1 of 2 Oster 3905 Outer Shell Replacement: step 6, image 2 of 2
      • Take off both rubber feet using a small metal spudger.
      • Wedge a spudger under the feet and pull up to pop off.
      Ask FixBot
    3. Oster 3905 Outer Shell Replacement: step 7, image 1 of 1
      • Use a PH#2 screw bit to remove eight 12mm screws that are located around the perimeter.
      • There are two screws under the rubber feet.
      Ask FixBot
    4. Oster 3905 Outer Shell Replacement: step 8, image 1 of 1
      • Place the toaster right side up.
      Ask FixBot
    5. Oster 3905 Outer Shell Replacement: step 9, image 1 of 2 Oster 3905 Outer Shell Replacement: step 9, image 2 of 2
      • Grab the outer shell firmly and pull up towards the face of the toaster.
      Ask FixBot
    6. Oster 3905 Outer Shell Replacement: step 10, image 1 of 1
      • For this part, you might need to wiggle the toaster to get the outer shell off.
      • The shell will not completely come off until the motherboard is removed in the next step.
      Ask FixBot
    7. Oster 3905 Outer Shell Replacement: step 11, image 1 of 3 Oster 3905 Outer Shell Replacement: step 11, image 2 of 3 Oster 3905 Outer Shell Replacement: step 11, image 3 of 3
      • Use a J1 screw bit to unscrew eight 8mm screws from the motherboard.
      Ask FixBot
    8. Oster 3905 Outer Shell Replacement: step 12, image 1 of 2 Oster 3905 Outer Shell Replacement: step 12, image 2 of 2
      • Take out the grey “cancel” and “bagel” buttons from the shell.
      Ask FixBot
Author
with
Melissa
198 Reputation
1 Guide authored
CSU Fullerton, Team 2-1, Bruce Fall 2016 Member of CSU Fullerton, Team 2-1, Bruce Fall 2016
CSUF-BRUCE-F16S2G1
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 332
