Osram Lightify Disassembly
View statistics:
Past 24 Hours:
Past 7 Days:
12
Past 30 Days:
57
All Time:
736
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide shows how to disassemble the Osram Lightify gateway.
Tools
    1. Osram Lightify Disassembly, Osram: step 1, image 1 of 1
      • Remove the front using a metal spudger.
      • Once you can get your fingers in, remove the rest using your hand.
      Ask FixBot
    2. Osram Lightify Disassembly: step 2, image 1 of 2 Osram Lightify Disassembly: step 2, image 2 of 2
      • On the back of the front cover, remove the white plastic using a metal spudger.
      • Remove the PCB using a spudger
      Ask FixBot
    3. Osram Lightify Disassembly: step 3, image 1 of 2 Osram Lightify Disassembly: step 3, image 2 of 2
      • Once the PCB is removed, use a Torx T9 screwdriver to unscrew and remove the power supply.
      • Remove the screws holding on the back cover with a Torx T9 screwdriver and remove the back cover.
      • all the screws are the same. they can be mixed with no problem.
      Ask FixBot
    4. Osram Lightify Disassembly: step 4, image 1 of 3 Osram Lightify Disassembly: step 4, image 2 of 3 Osram Lightify Disassembly: step 4, image 3 of 3
      • Remove the button by grabbing the tab over the button and pulling it out.
      • it will not come out if the button is not depressed.
      • Remove both metal sheets. when its at an angle, push it in a little and then pull it up so that it is pointing straight up. then, you can push it through.
      Ask FixBot
Aiden
18,541 Reputation
21 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 57
All Time: 736
