Introduction
Follow the steps in this guide to replace the broken microphone of your Oregon Scientific Meep! 4.0 tablet.
  1. Use a screwdriver to remove the four 7.0 mm Philips #00 screws from the back of the device.
    • Use a screwdriver to remove the four 7.0 mm Philips #00 screws from the back of the device.
  2. Use a plastic opening tool to detach the clips on the inside of the device.
    • Use a plastic opening tool to detach the clips on the inside of the device.
    • Use a screwdriver to remove the three 7.0 mm Philips #00 screws and unscrew the motherboard.
    • Use a plastic opening tool to release the three ribbon cables attached to the motherboard.
    • Lift up the motherboard and use a soldering station to remove the microphone from its wires.
Jess Forte
419 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 94
