Oregon Scientific BAR339DP Light Projector Repurpose
  1. Oregon Scientific BAR339DP Light Projector Repurpose, Light Projector Conversion: step 1, image 1 of 1
    • Instead of showing the clock/weather in the projection, you'll end up to see a large red disc.
    • This is going to REPLACE the existing functionality and is most likely not undoable.
    • Proceed at your own risk!
  2. Oregon Scientific BAR339DP Light Projector Repurpose, Remove the housing: step 2, image 1 of 3 Oregon Scientific BAR339DP Light Projector Repurpose, Remove the housing: step 2, image 2 of 3 Oregon Scientific BAR339DP Light Projector Repurpose, Remove the housing: step 2, image 3 of 3
    • Gently pry open the front case of the projector module.
    • Undo the 6 screws using a small Phillips screwdriver and remove the cover.
    • Pull on the projection assembly to detach it from the case. The top part, containing the lens is detachable by hand, the bottom one has 3 clips and a nut that secures it.
  3. Oregon Scientific BAR339DP Light Projector Repurpose, Disassemble the projector unit: step 3, image 1 of 3 Oregon Scientific BAR339DP Light Projector Repurpose, Disassemble the projector unit: step 3, image 2 of 3 Oregon Scientific BAR339DP Light Projector Repurpose, Disassemble the projector unit: step 3, image 3 of 3
    • Using a flat screwdriver/pryer press on the tabs on both sides of the assembly to make them loose.
    • Gently press on the upper piece of plastic, to the top.
    • Unscrew the large nut.
  4. Oregon Scientific BAR339DP Light Projector Repurpose, Decision time: step 4, image 1 of 3 Oregon Scientific BAR339DP Light Projector Repurpose, Decision time: step 4, image 2 of 3 Oregon Scientific BAR339DP Light Projector Repurpose, Decision time: step 4, image 3 of 3
    • After you disassemble the projector case, you can see the projector light, the passthrough display and the board that powers it.
    • You have 2 options:
    • Try to remove the connecting flex cable between the display and the board and replace it/repair it or clean the contacts on both ends. [I have tried this without success as the wires ripped off because they were aged]
    • Remove the display from the position (with or without removing the flex cable) and allow the projecting light to go through the lens directly - this way you obtain a big round red light: Mars on your wall!
  5. Oregon Scientific BAR339DP Light Projector Repurpose: step 5, image 1 of 2 Oregon Scientific BAR339DP Light Projector Repurpose: step 5, image 2 of 2
    • The red light is very bright, now it's time to reassemble the device in the reverse order!
    • In case you decided to remove the LCD screen, you should end up with a projection as seen in the picture taken in a dark room.
    • Enjoy your new ceiling light!
bmdbest
593 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 14
All Time: 457
