Oral-B White Pro 1000 Motherboard Replacement
  1. Oral-B White Pro 1000 Motherboard Replacement, Motherboard: step 1, image 1 of 1
    • Remove brush head by pulling the top away from the base.
  2. Oral-B White Pro 1000 Motherboard Replacement: step 2, image 1 of 3 Oral-B White Pro 1000 Motherboard Replacement: step 2, image 2 of 3 Oral-B White Pro 1000 Motherboard Replacement: step 2, image 3 of 3
    • Pry open the end cap from the toothbrush body.
    • Remove spring
  3. Oral-B White Pro 1000 Motherboard Replacement: step 3, image 1 of 2 Oral-B White Pro 1000 Motherboard Replacement: step 3, image 2 of 2
    • Apply pressure on the brush shaft to release the toothbrush internals.
    • Remove the internals through the bottom of the toothbrush body.
  4. Oral-B White Pro 1000 Motherboard Replacement: step 4, image 1 of 2 Oral-B White Pro 1000 Motherboard Replacement: step 4, image 2 of 2
    • Use flat head screwdriver to remove power button pressure plate.
  5. Oral-B White Pro 1000 Motherboard Replacement: step 5, image 1 of 3 Oral-B White Pro 1000 Motherboard Replacement: step 5, image 2 of 3 Oral-B White Pro 1000 Motherboard Replacement: step 5, image 3 of 3
    • Desolder the coil wire from the motherboard.
    • Check out this helpful guide for some soldering and desoldering tips.
    • Squeeze and remove coil from motherboard.
  6. Oral-B White Pro 1000 Motherboard Replacement: step 6, image 1 of 2 Oral-B White Pro 1000 Motherboard Replacement: step 6, image 2 of 2
    • Desolder the motor from motherboard.
    • Remove motherboard and battery from body of toothbrush internals.
  7. Oral-B White Pro 1000 Motherboard Replacement: step 7, image 1 of 2 Oral-B White Pro 1000 Motherboard Replacement: step 7, image 2 of 2
    • Desolder the battery connections from the motherboard.
    • Remove motherboard from battery holder.
Hannah Parker
203 Reputation
1 Guide authored
IUPUI, Team S5-G4, Baechle Fall 2017 Member of IUPUI, Team S5-G4, Baechle Fall 2017
IUPUI-BAECHLE-F17S5G4
3 Members
6 Guides authored
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 57
All Time: 2,662
