Optoma HD72 Motherboard Replacement
    1. Optoma HD72 Motherboard Replacement, Upper Case: step 1, image 1 of 2 Optoma HD72 Motherboard Replacement, Upper Case: step 1, image 2 of 2
      • Use a Phillips screwdriver to remove the five 2 mm screws on the underside of the device.
      Ask FixBot
    2. Optoma HD72 Motherboard Replacement: step 2, image 1 of 1
      • Flip the device over and slightly lift the upper case, with care not to strain the two cables.
      • Disconnect the two cables that connect the top case to the motherboard.
      • Lift the upper case up and off.
      Ask FixBot
    1. Optoma HD72 Motherboard Replacement, Motherboard: step 3, image 1 of 3 Optoma HD72 Motherboard Replacement, Motherboard: step 3, image 2 of 3 Optoma HD72 Motherboard Replacement, Motherboard: step 3, image 3 of 3
      • Disconnect all of the cables that are connected to the motherboard.
      Ask FixBot
    2. Optoma HD72 Motherboard Replacement: step 4, image 1 of 1
      • Remove the four 2 mm Phillips screws that secure the motherboard.
      • Lift the motherboard up and out of the chassis.
      Ask FixBot
Connor Bassolino
25,166 Reputation
125 Guides authored
iFixit Member of iFixit
Staff
123 Members
42,946 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 15
All Time: 225
