Optical Drive Enclosure Faceplate
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Optical Drive Enclosure Faceplate, Optical Drive Enclosure Faceplate: step 1, image 1 of 1
    • Remove the three 3.0 mm Phillips #0 screws from the optical bay enclosure.
  2. Optical Drive Enclosure Faceplate: step 2, image 1 of 3 Optical Drive Enclosure Faceplate: step 2, image 2 of 3 Optical Drive Enclosure Faceplate: step 2, image 3 of 3
    • Starting from the left edge, gently pull open the optical bay enclosure.
    • Continue to pull open the two halves of the enclosure until they separate.
  3. Optical Drive Enclosure Faceplate: step 3, image 1 of 1
    • Remove the two 3.0 mm Phillips #0 screws securing the faceplate to the optical bay enclosure.
  4. Optical Drive Enclosure Faceplate: step 4, image 1 of 3 Optical Drive Enclosure Faceplate: step 4, image 2 of 3 Optical Drive Enclosure Faceplate: step 4, image 3 of 3
    • Lift the black plastic faceplate out of the optical bay enclosure.
    • You will no longer need the faceplate or the two Phillips screws that held it in place. Set those parts aside if you ever wish to put the faceplate back into the enclosure.
    • Reassemble the optical bay enclosure without the faceplate, reusing the original three 3.0 mm Phillips screws to keep it intact.
Brittany McCrigler
89,020 Reputation
131 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,420 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 737
