Optical Bay Enclosure Dual Hard Drive Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Optical Bay Enclosure Dual Hard Drive Replacement, Dual Hard Drive: step 1, image 1 of 2 Optical Bay Enclosure Dual Hard Drive Replacement, Dual Hard Drive: step 1, image 2 of 2
    • Remove the plastic positioner from the optical bay hard drive enclosure by pressing in on one of the clips on either side and lifting it up and out of the enclosure.
  2. Optical Bay Enclosure Dual Hard Drive Replacement: step 2, image 1 of 3 Optical Bay Enclosure Dual Hard Drive Replacement: step 2, image 2 of 3 Optical Bay Enclosure Dual Hard Drive Replacement: step 2, image 3 of 3
    • Make sure that the hard drive connectors are facing down before placing it into the enclosure.
    • Gently place the hard drive into the enclosure's hard drive slot.
    • While firmly holding the enclosure in place with one hand, use your other hand to press the hard drive into the enclosure connectors.
  3. Optical Bay Enclosure Dual Hard Drive Replacement: step 3, image 1 of 2 Optical Bay Enclosure Dual Hard Drive Replacement: step 3, image 2 of 2
    • Once the hard drive is snug, reinsert the plastic positioner while holding the hard drive against the bottom of the enclosure.
    • Reconnect any cables you have removed from the original optical drive onto the optical bay enclosure.
Brittany McCrigler
89,020 Reputation
131 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,430 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 260
