Nvidia Shield Pro Android TV Bottom Cover Replacement
  1. Nvidia Shield Pro Android TV Bottom Cover Replacement, Bottom Cover: step 1, image 1 of 2 Nvidia Shield Pro Android TV Bottom Cover Replacement, Bottom Cover: step 1, image 2 of 2
    • Flip to the back side of your Nvidia Shield Pro Android TV.
    • To open the bottom cover of the Nvidia Shield, start from the corner and slide your plastic opening tool across the gap.
    • If using a plastic opening tool to open the bottom cover is difficult, try using a metal spudger.
Christian De Vera
167 Reputation
1 Guide authored
Cal Poly, Team S18-G2, White Winter 2020 Member of Cal Poly, Team S18-G2, White Winter 2020
CPSU-WHITE-W20S18G2
4 Members
14 Guides authored
1 Guide Comment
Hi, Shield Pro 2.
Remove 2 small cross head screws securing top cover to the back plate. Next you have to pry open the back edge and then slide the top cover forwards about 8mm away from the back plate to clear 3 catch points along each side.
S. Carter - Reply
Past 24 Hours: 6
Past 7 Days: 20
Past 30 Days: 72
All Time: 2,802
