Opening the Mac Pro First Generation Case
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Opening the Mac Pro First Generation Case, Case Panel: step 1, image 1 of 1
    • Lift the lever to unlock the case.
  2. Opening the Mac Pro First Generation Case: step 2, image 1 of 1
    • Remove the side panel of the Mac Pro.
    • Discharge any static electricity by touching a grounded surface prior to working on any internal components. Touching the metal PCI slot covers works great, or any other grounded metal surface. You can also wear a anti-static wrist strap.
Andrew Kim
1,263 Reputation
3 Guides authored
Cal Poly, Team 6-24, Maness Fall 2014 Member of Cal Poly, Team 6-24, Maness Fall 2014
CPSU-MANESS-F14S6G24
4 Members
13 Guides authored
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 4
All Time: 57
