Introduction
A quick rundown of how to open up the M170's screwless outer casing. This would be the first step before being able to repair any of the internal components.
This mouse isn't held together with screws. This guide will teach you where to find the 3 clips and 2 hooks that hold the top part of the case in place.
Switch off the mouse and slide out the bottom cover. This is where all the necessary clips can be accessed.
Remove the battery and sticker. There are a total of 3 clips that need to be released. Two are just on the sides. The third one is under the sticker inside the battery's chamber. Logitech commonly hides extra fastening points in a similar place in their other wireless mice.
We'll release the clips in the next step.
Identify the clips. The plastic of the top cover is a different color from the plastic of the base. You can identify the clips from their color (should be the color of the top cover. Here, they are black).
When you've identified the clips, pull them outward/away from the center (see image) to release them.
After you've released the 3 clips, you should be free to pop the top cover right off. You can help it along by pushing on one of the clips.
After the back part pops off, slide the whole top cover forward a little. (There are two more hooks in front of the mouse where the buttons are, that normally prevent you from pulling the buttons upward.) That should let you remove the whole thing.
From here, you should be able to do your repairs on the internals.
Interesting thing to note: Logitech switched some of their higher-end mice to high-quality Omron switches. But this, being a $12-ish mouse, seems to use microswitches from Himake. The actuation force feels noticeably higher vs Omron switches. Durability is up for testing and debate. I personally haven't owned this mouse long enough to tell.
I like how it was screwless and didn't have any adhesives. It makes it really easy to put back together and it means there are fewer things to lose or keep track of.
Press down on the palm part of the top cover gentry to snap the back clips into place.
