Up to 20% off select tools
Opening Case
Views: 2.7K
View statistics:
Past 24 Hours:
4
Past 7 Days:
18
Past 30 Days:
91
All Time:
2,739
Comments: 2
2 comments on steps.
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 3 - 5 minutes
Difficulty: Easy
Community-Contributed Guide
Opening Case
Tools
Introduction
Go to step 1 ↓
This Prerequisite-Only guide shows how to open and butterfly the 8BitDo SN30 Pro+
    1. Opening Case, Remove Battery: step 1, image 1 of 3 Opening Case, Remove Battery: step 1, image 2 of 3 Opening Case, Remove Battery: step 1, image 3 of 3
      • Place the controller face down.
      • Remove the battery cover.
      • Remove rechargeable battery or AA batteries.
      Ask FixBot
    2. Opening Case, Remove Trigger Buttons: step 2, image 1 of 2 Opening Case, Remove Trigger Buttons: step 2, image 2 of 2
      • Remove L2 and R2 trigger buttons by pushing them away from the grips.
      Ask FixBot
    3. Opening Case, Remove Screws: step 3, image 1 of 2 Opening Case, Remove Screws: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Use Tweezers to uncover two screws under the label in the battery compartment.
      • Use a T6 screwdriver to remove the four 7.3 mm screws securing the rear cover.
      Ask FixBot
    4. Opening Case, Unclip Covers: step 4, image 1 of 3 Opening Case, Unclip Covers: step 4, image 2 of 3 Opening Case, Unclip Covers: step 4, image 3 of 3
      • At the end of each grip, pry apart the covers.
      • Use fingernail or opening pick to undo the two top clips.
      • One clip next to L button.
      • One clip next to R button
      • Undo the final clip between the joysticks.
      Ask FixBot
    5. Opening Case, Separate Covers: step 5, image 1 of 1
      • Carefully move the rear cover away and from the front cover. Place it to the left.
      • Do not completely separate. The two halves are still attached via a white ribbon cable.
      Ask FixBot
4 other people completed this guide.
Author
with
Brian W
1,800 Reputation
8 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 91
All Time: 2,739
