Up to 20% off select tools
Open the housing
View statistics:
Past 24 Hours:
0
Past 7 Days:
6
Past 30 Days:
16
All Time:
162
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Community-Contributed Guide
Open the housing
Tools
Introduction
Go to step 1 ↓
These instructions show you how to open your laptop. This is necessary for many repairs, such as replacing the battery or SSD.
    1. Open the housing, Remove the case screws: step 1, image 1 of 1
      • Close the laptop, place it on its lid, and align it as shown in the image
      • There are three different screw lengths:
      • 4 x PH1 12 mm (orange)
      • 3 x PH1 10 mm (yellow)
      • 4 x PH1 7 mm (green)
      • The screws must be reinstalled in the correct position later, otherwise something can be damaged.
      • Take out the screws and sort them by length.
      Ask FixBot
    2. Open the housing, Remove the keyboard: step 2, image 1 of 1
      • Turn the device over and open it.
      • Once the keyboard is detached, you must remove the 4 ribbon cables before you can remove the keyboard!
      • Carefully insert the Jimmy into the gap between the case and the keyboard at the lower right corner of the keyboard.
      • From this position, work your way forward by levering alternately to the left and up until the keyboard is loose on the case.
      Ask FixBot
    3. Open the housing, Unplug the keyboard cable and remove the keyboard: step 3, image 1 of 2 Open the housing, Unplug the keyboard cable and remove the keyboard: step 3, image 2 of 2
      • There are 4 cables that must be removed!
      • Carefully open the keyboard under the touchpad, move it in the direction of the screen.
      • Use the spudger to lift the black lock on the ribbon cable and carefully pull out the cable. Repeat this for each one of the four ribbon cables.
      Ask FixBot
    4. Open the housing, Disconnect the battery: step 4, image 1 of 3 Open the housing, Disconnect the battery: step 4, image 2 of 3 Open the housing, Disconnect the battery: step 4, image 3 of 3
      • Locate the battery connector.
      • Carefully slide the metal clip (marked blue in the picture) upwards to unlock the connector.
      • Use the spudger to lift the white connector upwards.
      Ask FixBot
Follow the steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
Author
with
buntstift
1,293 Reputation
13 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 16
All Time: 162
