Up to 20% off select tools
Open the enclosure
Views: 3K
View statistics:
Past 24 Hours:
10
Past 7 Days:
99
Past 30 Days:
321
All Time:
2,953
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 30 minutes
Difficulty: Moderate
Community-Contributed Guide
Open the enclosure
Parts
Tools
Introduction
Go to step 1 ↓
These instructions describe how to open the razor enclosure. This is a prerequisite for further steps such as replacing the battery or the drive.
    1. Open the enclosure, Remove the bottom cover: step 1, image 1 of 2 Open the enclosure, Remove the bottom cover: step 1, image 2 of 2
      • To do this, unfasten and remove the Torx T6 screw
      • Then pull off the cover.
      Ask FixBot
    2. Open the enclosure, Remove the lower (rear) housing cover: step 2, image 1 of 2 Open the enclosure, Remove the lower (rear) housing cover: step 2, image 2 of 2
      • To do this, extend the trimmer, i.e., push it upward from the bottom position toward the shaving head (red arrow)
      • Pull (green arrows) the covers on the left and right of the trimmer over the retaining pins (green rings)
      • Then pull them downward toward the bottom to remove them.
      Ask FixBot
    3. Open the enclosure, Remove the side panels of the outer trim: step 3, image 1 of 2 Open the enclosure, Remove the side panels of the outer trim: step 3, image 2 of 2
      • Remove the upper side panels of the front outer trim on the left and right.
      Ask FixBot
    4. Open the enclosure, Remove the front enclosure cover: step 4, image 1 of 3 Open the enclosure, Remove the front enclosure cover: step 4, image 2 of 3 Open the enclosure, Remove the front enclosure cover: step 4, image 3 of 3
      • Remove the front enclosure cover (outer panel). To do this, carefully pry the three side eyelets on the left and right slightly over the retaining tabs with a spatula.
      • Carefully lift off the enclosure cover.
      Ask FixBot
      • Remove the switch cover. To do this, carefully pry the retaining tabs on the left and right over the retaining lugs.
      • Then lift off the exposed rocker switch at the top.
      Ask FixBot
      • To do this, remove the four Torx T8 screws that are visible on the front left and right sides.
      • The tongue and groove opposite the case and cover can be pushed apart using a spatula.
      • The positive terminal of the 18500 cell points downward (shaving head at the top).
      Ask FixBot
Follow the steps in reverse order to reassemble your device.
3 other people completed this guide.
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
Author
with
BluRay
513 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 99
Past 30 Days: 321
All Time: 2,953
