OontZ Angle 3 Back Case Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. OontZ Angle 3 Back Case Replacement, Back Case: step 1, image 1 of 3 OontZ Angle 3 Back Case Replacement, Back Case: step 1, image 2 of 3 OontZ Angle 3 Back Case Replacement, Back Case: step 1, image 3 of 3
      • Make sure that the OontZ Angle 3 is powered off before starting the disassembly.
      • Use the plastic opening tool to remove the rubber caps from each end of the speaker.
      Ask FixBot
    2. OontZ Angle 3 Back Case Replacement: step 2, image 1 of 1
      • Remove four (4) 11.7 mm Phillips #0 screws from each side at the bottom of the speaker.
      Ask FixBot
    3. OontZ Angle 3 Back Case Replacement: step 3, image 1 of 2 OontZ Angle 3 Back Case Replacement: step 3, image 2 of 2
      • Use the plastic opening tool on one of the corners to separate the bottom piece from the speaker, and then remove the piece.
      Ask FixBot
Mason Hollander
1,616 Reputation
4 Guides authored
USF Tampa, Team 15-6, Remmell Spring 2016 Member of USF Tampa, Team 15-6, Remmell Spring 2016
USFT-REMMELL-S16S15G6
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 10
All Time: 229
