Shop the Holiday Gift Guide
OnePlus 6 Back Panel Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
8
Past 30 Days:
19
All Time:
257
Comments: 4
4 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 25 minutes
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
If your OnePlus 6 is having hardware malfunctions or if your in need for a new battery, use this guide to gain access into the core of the phone. This guide serves as the backbone to fixing any issues that may arise inside of the phone.
The back panel of the OnePlus 6 unlocks worlds of opportunity for reparability and is the casing for all the parts inside of the phone. Before taking the back panel off, make sure to take a look at the OnePlus 6 Troubleshooting page to see if there is a simple fix to any problem you may be having before taking the next step to replace anything.
Even though taking a dive into the repair world is fascinating, be careful while following this guide because the back of the OnePlus 6 is generally made out of glass, so be careful not to shatter it.
Before performing this guide and any procedures to follow, make sure that the phone is powered off and that there are no outside power sources plugged in.
Tools
    1. OnePlus 6 Back Panel Replacement, Back Panel: step 1, image 1 of 1
      • Turn on the heat gun to a low heat and and gently heat the curved edges on the back of the phone.
      • Be careful not to overheat or melt the plastic; heat guns can get out of hand quickly!
      • Wedge the opening picks between the front and back panel and slide them around the perimeter to break the adhesive securing the back cover.
      • Repeat until the back panel is fully released.
      Ask FixBot
    2. OnePlus 6 Back Panel Replacement: step 2, image 1 of 2 OnePlus 6 Back Panel Replacement: step 2, image 2 of 2
      • Gently lift up the back panel, with care not to damage the fingerprint sensor ribbon cable.
      Ask FixBot
    3. OnePlus 6 Back Panel Replacement: step 3, image 1 of 2 OnePlus 6 Back Panel Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Use a pair of tweezers to gently pull up on the red tab and disconnect the cable from the device.
      • Completely remove the back panel from the device.
      Ask FixBot
Author
with
Mickenzie Thompson
373 Reputation
3 Guides authored
Clemson, Team 4-3, Hunter Fall 2021 Member of Clemson, Team 4-3, Hunter Fall 2021
CLEM-HUNTER-F21S4G3
5 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 19
All Time: 257
