Shop the Holiday Gift Guide
OnePlus 5 Battery Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
8
Past 30 Days:
12
All Time:
126
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 - 30 minutes
Difficulty: Moderate
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Introduction
Go to step 1 ↓
For an updated guide, follow this link. This guide has been archived for historical purposes.
This is a guide for replacing a faulty battery in the OnePlus 5. Replacing the battery does not void the OnePlus 5's warranty. No special skills are needed for this replacement. The battery contains toxic chemicals which are hazardous so be careful not to puncture it.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
    1. OnePlus 5 Battery  Replacement, Battery: step 1, image 1 of 3 OnePlus 5 Battery  Replacement, Battery: step 1, image 2 of 3 OnePlus 5 Battery  Replacement, Battery: step 1, image 3 of 3
      • Notice the cable that goes across the yellow battery from the top to the bottom. There is a connector for this cable at the bottom of the battery.
      • Remove this cable by pushing a spudger underneath the connector and popping it out.
      Ask FixBot
    2. OnePlus 5 Battery  Replacement: step 2, image 1 of 3 OnePlus 5 Battery  Replacement: step 2, image 2 of 3 OnePlus 5 Battery  Replacement: step 2, image 3 of 3
      • Notice the two clear adhesive flaps overlapping on the left and right side of the yellow battery.
      • Peel back these flaps by running the spudger between the the flaps and battery, seperating the adhesive.
      • When reassembling the device, the spudger is not needed. Fold the flaps over so that the sticky side touches the yellow battery and connect the adhesive.
      • Be careful not to push too hard with the nylon spudger as you may pierce the battery and release toxic chemicals.
      Ask FixBot
    3. OnePlus 5 Battery  Replacement: step 3, image 1 of 3 OnePlus 5 Battery  Replacement: step 3, image 2 of 3 OnePlus 5 Battery  Replacement: step 3, image 3 of 3
      • Remove the yellow battery by pulling up and to the left on the green pull-tab.
      • This will create a ripping sound. This is because of the adhesive on the back of the battery and is completely normal.
      Ask FixBot
Jose Velazquez
872 Reputation
4 Guides authored
Cal Poly, Team S19-G1, Livingston Winter 2018 Member of Cal Poly, Team S19-G1, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G1
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 12
All Time: 126
