OneLink Safe and Sound Motherboard Replacement
    1. OneLink Safe and Sound Motherboard Replacement, Cover: step 1, image 1 of 2 OneLink Safe and Sound Motherboard Replacement, Cover: step 1, image 2 of 2
      • Run the metal spudger under the plastic rim and around the perimeter, on the top of the device to loosen the adhesive.
      • Remove plastic rim.
      Ask FixBot
    2. OneLink Safe and Sound Motherboard Replacement: step 2, image 1 of 2 OneLink Safe and Sound Motherboard Replacement: step 2, image 2 of 2
      • Use a Phillips #0 screwdriver to remove nine screws from the top of the device.
      Ask FixBot
    3. OneLink Safe and Sound Motherboard Replacement: step 3, image 1 of 2 OneLink Safe and Sound Motherboard Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Don't yank or pull the lid off as there are ribbons and cables connecting the top of the device to the motherboard. They need to be disconnected before the top is removed.
      • Use tweezers or a spudger to disconnect the ribbon from the motherboard.
      Ask FixBot
    4. OneLink Safe and Sound Motherboard Replacement: step 4, image 1 of 1
      • Use tweezers to unplug the speaker cable from the motherboard.
      Ask FixBot
    5. OneLink Safe and Sound Motherboard Replacement: step 5, image 1 of 2 OneLink Safe and Sound Motherboard Replacement: step 5, image 2 of 2
      • Use the plastic opening tool to remove the microphone connection from the motherboard.
      • Remove the top of the device.
      Ask FixBot
    1. OneLink Safe and Sound Motherboard Replacement, Battery: step 6, image 1 of 1
      • Use the plastic opening tool to disconnect the cable from the motherboard.
      Ask FixBot
    2. OneLink Safe and Sound Motherboard Replacement: step 7, image 1 of 2 OneLink Safe and Sound Motherboard Replacement: step 7, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the single screw securing the plastic battery cage.
      Ask FixBot
    3. OneLink Safe and Sound Motherboard Replacement: step 8, image 1 of 2 OneLink Safe and Sound Motherboard Replacement: step 8, image 2 of 2
      • Remove the plastic cage holding the battery in place.
      • Remove the battery from the device.
      Ask FixBot
    1. OneLink Safe and Sound Motherboard Replacement, Bluetooth Module: step 9, image 1 of 1
      • Use the opening tool to disconnect the Wi-Fi cable from the Bluetooth module.
      Ask FixBot
    2. OneLink Safe and Sound Motherboard Replacement: step 10, image 1 of 2 OneLink Safe and Sound Motherboard Replacement: step 10, image 2 of 2
      • Lift the Bluetooth module off of the daughterboard.
      • Lift it straight up to avoid bending the delicate pins that connect the Bluetooth module to the board.
      Ask FixBot
    1. OneLink Safe and Sound Motherboard Replacement, Motherboard: step 11, image 1 of 3 OneLink Safe and Sound Motherboard Replacement, Motherboard: step 11, image 2 of 3 OneLink Safe and Sound Motherboard Replacement, Motherboard: step 11, image 3 of 3
      • Use the opening tool to disconnect the speaker cables from the daughterboard.
      • Use the opening to lift the daughterboard off of the motherboard.
      • The daughterboard is sitting on a white plastic base on top of the motherboard.
      Ask FixBot
    2. OneLink Safe and Sound Motherboard Replacement: step 12, image 1 of 2 OneLink Safe and Sound Motherboard Replacement: step 12, image 2 of 2
      • Use a Phillips #0 screwdriver to remove seven screws securing the white base and motherboard.
      Ask FixBot
    3. OneLink Safe and Sound Motherboard Replacement: step 13, image 1 of 3 OneLink Safe and Sound Motherboard Replacement: step 13, image 2 of 3 OneLink Safe and Sound Motherboard Replacement: step 13, image 3 of 3
      • Gently remove the motherboard.
      Ask FixBot
Arianna Roberts
687 Reputation
6 Guides authored
UMass Dartmouth, Team 2-2, Petersen Fall 2022 Member of UMass Dartmouth, Team 2-2, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G2
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 51
All Time: 509
