One Education Infinity:One Battery Replacement
  1. One Education Infinity:One Battery Replacement, Top Case: step 1, image 1 of 3 One Education Infinity:One Battery Replacement, Top Case: step 1, image 2 of 3 One Education Infinity:One Battery Replacement, Top Case: step 1, image 3 of 3
    • Insert a Jimmy or other prying tool into the seam between the screen and back case.
    • Trace around the edges until all clips are released.
    • Lift the back case away from the tablet.
  2. One Education Infinity:One Battery Replacement, Battery: step 2, image 1 of 2 One Education Infinity:One Battery Replacement, Battery: step 2, image 2 of 2
    • Use a spudger to disconnect the black bundled cable connector from the motherboard.
  3. One Education Infinity:One Battery Replacement: step 3, image 1 of 3 One Education Infinity:One Battery Replacement: step 3, image 2 of 3 One Education Infinity:One Battery Replacement: step 3, image 3 of 3
    • Use a spudger to lift the black tab on top of the ZIF connector.
    • Slide the ribbon cable out of the connector.
  4. One Education Infinity:One Battery Replacement: step 4, image 1 of 3 One Education Infinity:One Battery Replacement: step 4, image 2 of 3 One Education Infinity:One Battery Replacement: step 4, image 3 of 3
    • Use a spudger to flip up the black retaining flap on the ZIF connector.
    • Pull the folded ribbon cable straight out of the connector.
    • This ribbon cable must be disconnected before removing the battery because it is attached to the battery with adhesive.
  5. One Education Infinity:One Battery Replacement: step 5, image 1 of 1
    • Use a spudger to pry the battery away from the device.
    • Always use ESD safe tools when working with delicate electrical components.
Taylor Bratsch
5,742 Reputation
14 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 12
All Time: 984
