Omaker M4 Back Case Replacement
  1. Omaker M4 Back Case Replacement, Back Case: step 1, image 1 of 1
    • Flip the device over so the front of the speaker is facing down. Make sure to place the speaker on a flat surface
  2. Omaker M4 Back Case Replacement: step 2, image 1 of 2 Omaker M4 Back Case Replacement: step 2, image 2 of 2
    • Use a T6 Torx screwdriver to remove the four 9mm screws from the back of the device.
  3. Omaker M4 Back Case Replacement: step 3, image 1 of 2 Omaker M4 Back Case Replacement: step 3, image 2 of 2
    • Use a magnet to remove the screws after unscrewing them and place them aside.
  4. Omaker M4 Back Case Replacement: step 4, image 1 of 1
    • Carefully remove the back cover without breaking the battery wire.
  5. Omaker M4 Back Case Replacement: step 5, image 1 of 2 Omaker M4 Back Case Replacement: step 5, image 2 of 2
    • Remove the end of the battery connection from the motherboard by holding the end of the wire and carefully pulling it out of the socket using tweezers.
    • The battery is still attached to the back cover.
[deleted]
679 Reputation
4 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 808
