Fix Your Stuff
Right to Repair
Store
You're viewing a previously published version of this guide.  View latest version
Older Newer
Introduction
This guide will help you replace your LCD screen.
  1. Remove the two 4mm screws from each side of the camera with a Phillips PH000 screwdriver. Remove the two 4mm screws from each side of the camera with a Phillips PH000 screwdriver.
    • Remove the two 4mm screws from each side of the camera with a Phillips PH000 screwdriver.
  2. Remove the four 4mm screws from the bottom of the camera with a Phillips PH000 screwdriver.
    • Remove the four 4mm screws from the bottom of the camera with a Phillips PH000 screwdriver.
  3. Use the plastic opening tools and your fingers to pry the front plate from the camera. You might need to open the battery cover to remove the front plate. You might need to open the battery cover to remove the front plate.
    • Use the plastic opening tools and your fingers to pry the front plate from the camera.
    • You might need to open the battery cover to remove the front plate.
  4. Use your fingers to pry open the back cover. When you remove the back of the camera, the button membrane might fall out. Don’t lose this sheet.
    • Use your fingers to pry open the back cover.
    • When you remove the back of the camera, the button membrane might fall out. Don’t lose this sheet.
    • The LCD screen is connected to the body of the camera by an orange ribbon cable. Don’t pull this ribbon cable out.
  5. Using the Phillips PH000 screwdriver, remove the 4mm screw from the bottom left corner of the button plate located under the button membrane. Using the Phillips PH000 screwdriver, remove the 4mm screw from the bottom left corner of the button plate located under the button membrane.
    • Using the Phillips PH000 screwdriver, remove the 4mm screw from the bottom left corner of the button plate located under the button membrane.
  6. Pull the button pad up to fully reveal the visible ribbon cable.
    • Pull the button pad up to fully reveal the visible ribbon cable.
    • You might need to bend the button pad out of the way.
  7. Pull out the LCD screen and the ribbon cable.
    • Pull out the LCD screen and the ribbon cable.
    • The ribbon cable should be easy to pull out.
Chloe
112 Reputation
1 Guide authored
USF Tampa, Team 1-3, Leahy Winter 2015 Member of USF Tampa, Team 1-3, Leahy Winter 2015
USFT-LEAHY-W15S1G3
3 Members
10 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 668
