Olympus Stylus Tough TG-2 iHS Front Case Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Olympus Stylus Tough TG-2 iHS Front Case Replacement, Front Case: step 1, image 1 of 2 Olympus Stylus Tough TG-2 iHS Front Case Replacement, Front Case: step 1, image 2 of 2
    • Remove the red ring surrounding the lens by twisting it counter-clockwise
  2. Olympus Stylus Tough TG-2 iHS Front Case Replacement: step 2, image 1 of 2 Olympus Stylus Tough TG-2 iHS Front Case Replacement: step 2, image 2 of 2
    • Remove the 2 Phillips #00 3.4mm screws that secure the faceplate just reveled by the grip.
    • On the bottom of the camera, remove the single Phillips #00 3.4mm screw by the tripod socket securing the face plate.
  3. Olympus Stylus Tough TG-2 iHS Front Case Replacement: step 3, image 1 of 3 Olympus Stylus Tough TG-2 iHS Front Case Replacement: step 3, image 2 of 3 Olympus Stylus Tough TG-2 iHS Front Case Replacement: step 3, image 3 of 3
    • Use a plastic prying tool to lift and remove the faceplate .
    • There will be some resistance from a sticker just under the GPS logo.
    • The black plastic ring around the flash may fall as it is no longer secure.
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 66
