Introduction
Use this guide to replace a broken lens inside the camera.
Remove the four 3 mm long cover screws at the corners of the camera using a Phillips #00 screwdriver.
Remove the 2 mm long screws securing the sides of the camera which holds the back panel using a Phillips #00 screwdriver.
Detach the ribbons using your thumb, sliding them out of their slots.
Set the back panel face up to keep the ribbons from touching anything.
Remove the top screws using a 1.5 mm screwdriver.
Remove the single side screw located on the side of the camera where the tab is, using a #00 screwdriver.
Using a #00 Philips Head Screwdriver, remove the screws located on all four sides of the camera.
Remove the viewfinder lens using a prying device.
There will be two ribbons attached to the viewfinder. Remove the ribbons by sliding them off the viewfinder with your thumb.
