Disassembling Olympus Stylus 725 SW LCD Screen
  1. Disassembling Olympus Stylus 725 SW LCD Screen, Disassembling Olympus Stylus 725 SW Battery: step 1, image 1 of 2 Disassembling Olympus Stylus 725 SW LCD Screen, Disassembling Olympus Stylus 725 SW Battery: step 1, image 2 of 2
    • The battery is located on the bottom of the camera.
    • Remove the battery by placing your thumb on the bottom flap and sliding the release button away from the side the lens is on. (The screwdriver is simply used as a reference point, no screws need to be removed)
    • If the battery is dead, charge it for 60-90 minutes.
    • When installing a charged battery, align the battery appropriately. The positive signs and negative should line up.
  2. Disassembling Olympus Stylus 725 SW LCD Screen, Disassembling Olympus Stylus 725 SW Back Panel: step 2, image 1 of 3 Disassembling Olympus Stylus 725 SW LCD Screen, Disassembling Olympus Stylus 725 SW Back Panel: step 2, image 2 of 3 Disassembling Olympus Stylus 725 SW LCD Screen, Disassembling Olympus Stylus 725 SW Back Panel: step 2, image 3 of 3
    • Remove the four 3 mm long cover screws at the corners of the camera using a Phillips #00 screwdriver.
    • Remove the 2 mm long screws securing the sides of the camera which holds the back panel using a Phillips #00 screwdriver.
  3. Disassembling Olympus Stylus 725 SW LCD Screen: step 3, image 1 of 2 Disassembling Olympus Stylus 725 SW LCD Screen: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Be careful when removing the back cover; you will need to detach the connecting ribbons. Use tweezers if necessary.
    • Detach the ribbons using your thumb, sliding them out of their slots.
    • Set the back panel face up to keep the ribbons from touching anything.
  4. Disassembling Olympus Stylus 725 SW LCD Screen, Disassembling Olympus Stylus 725 SW LCD Screen: step 4, image 1 of 3 Disassembling Olympus Stylus 725 SW LCD Screen, Disassembling Olympus Stylus 725 SW LCD Screen: step 4, image 2 of 3 Disassembling Olympus Stylus 725 SW LCD Screen, Disassembling Olympus Stylus 725 SW LCD Screen: step 4, image 3 of 3
    • Use a #00 Phillips head screwdriver to remove the screws in the back panel.
    • After removing the back panel, slide the ribbons off the computer chip to detach them.
  5. Disassembling Olympus Stylus 725 SW LCD Screen: step 5, image 1 of 2 Disassembling Olympus Stylus 725 SW LCD Screen: step 5, image 2 of 2
    • Use tweezers to remove the loosened LCD screen.
    • Be careful to not scratch the new LCD screen when replacing it.
    • Carefully place the new screen in place of the old, making sure the label faces up.
    • Slide the ribbons back onto the computer chip.
    • Using the #00 Phillips head screwdriver from before, screw the screws in the back into the panel.
Bobby Hodges
49 Reputation
6 Guides authored
Cal Poly, Team 33-71, Johann Spring 2010 Member of Cal Poly, Team 33-71, Johann Spring 2010
CPSU-JOHANN-S10S33G71
4 Members
6 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 23
All Time: 8,023
