Introduction
You will need a clean, well-lit area, an iFixit repair kit including the specialized screw driver, along with the Phillips #000 bit. We also recommend you have an organization tray in order to keep track of all the screws you will be taking out.
Using a plastic opening tool, gently lift the retaining flap on the display cable ZIF connector.
Pull the display cable from its socket on the motherboard.
Remove the top left screw, top right screw, bottom left screw, and bottom right screw from LCD frame.
Lift the retaining flaps on the three remaining ZIF connectors connected to the motherboard.
Remove the five 4.3mm Phillips #000 screws from the lens frame to access the lens.
Remove the lens frame.
Remove two 4.3mm Phillips #000 screws from black plastic piece surrounding the lens.
Remove the lens.
