Removing Olympus FE-210 LCD Screen
  1. Removing Olympus FE-210 LCD Screen, Battery: step 1, image 1 of 2 Removing Olympus FE-210 LCD Screen, Battery: step 1, image 2 of 2
    • The battery compartment is located on the bottom side of the camera. Push the button in, and slide the cover to get access to the batteries.
  2. Removing Olympus FE-210 LCD Screen: step 2, image 1 of 2 Removing Olympus FE-210 LCD Screen: step 2, image 2 of 2
    • The batteries will slide right out.
    • When putting new batteries in, make sure they are pointing the right direction.
  3. Removing Olympus FE-210 LCD Screen, Front Casing: step 3, image 1 of 3 Removing Olympus FE-210 LCD Screen, Front Casing: step 3, image 2 of 3 Removing Olympus FE-210 LCD Screen, Front Casing: step 3, image 3 of 3
    • Remove the 7 screws holding the front case in place, with a #00 screwdriver.
    • Six screws are 3.6 mm.
    • The seventh screw is 3.2 mm.
  4. Removing Olympus FE-210 LCD Screen: step 4, image 1 of 3 Removing Olympus FE-210 LCD Screen: step 4, image 2 of 3 Removing Olympus FE-210 LCD Screen: step 4, image 3 of 3
    • Pulling the front case off, requires applying enough strength in the right areas.
    • The front case snaps into place in three places:
    • At the top and bottom of the battery side (opposite of side pictured) of the case.
    • Right in the middle of the DC-in side (side pictured) of the case.
    • Top of the camera, to the left of the power button.
    • Once those places are disconnected, the front case will pop right off.
    • The camera in the first two pictures is upside down. This is the best position to place your thumbs to remove the case.
  5. Removing Olympus FE-210 LCD Screen, Rear Casing: step 5, image 1 of 1
    • Remove the 3.2 mm screw in the battery compartment using a #00 screwdriver.
    • After removal of the screw the case will be loose, but do not tug it off. There is a cord connecting the rear controls to the motherboard.
  6. Removing Olympus FE-210 LCD Screen: step 6, image 1 of 3 Removing Olympus FE-210 LCD Screen: step 6, image 2 of 3 Removing Olympus FE-210 LCD Screen: step 6, image 3 of 3
    • Carefully pull the rear case away from the camera until you have access to the cord connected to the motherboard.
    • Lift the white latch using a fingernail or a spudger.
    • Pull the cord from its connector.
  7. Removing Olympus FE-210 LCD Screen, LCD Screen: step 7, image 1 of 2 Removing Olympus FE-210 LCD Screen, LCD Screen: step 7, image 2 of 2
    • Remove the two 2.7 mm screws using a #00 screwdriver.
    • After removing the screws the display will be free. Do not remove it. Like the rear case, there is a cord connecting it to the motherboard that must be disconnected first.
  8. Removing Olympus FE-210 LCD Screen: step 8, image 1 of 3 Removing Olympus FE-210 LCD Screen: step 8, image 2 of 3 Removing Olympus FE-210 LCD Screen: step 8, image 3 of 3
    • Using a spudger, lift the latch on the connector.
    • Remove the ribbon cord from its connector.
    • Remove the LCD from the rest of the camera.
Matt
811 Reputation
6 Guides authored
Cal Poly, Team 4-36, Regan Winter 2011 Member of Cal Poly, Team 4-36, Regan Winter 2011
CPSU-REGAN-W11S4G36
3 Members
14 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 5,244
