Introduction
This guide will give step-by-step instructions on how to install a LCD screen in a Olympus D590 camera.
To avoid disconnection of the connector line to the motherboard, use caution when pulling faceplate away from camera case.
Using a Phillips #00 screwdriver, remove three screws fastened to the camera backplate edge.
Using a Phillips #00 screwdriver, remove the two camera flash screws secured to either side of bulb housing component.
Remove the side pannel by sliding it off the body of the camera.
Lift the camera NO MORE than 3cm to make sure all screws have been taken off.
Flip camera so you are looking at the front.
Remove gray and blue wiring with tweasers by gently wiggling and pulling.
Locate the tape securing the wiring with the gray end piece located on top of the camera.
Gently lift the tape till all wires are exposed.
Flip Camera to the bottom side as shown.
Pull and wriggle the thin yellow wiring tape to detach it from the rest of the camera, while leaving it attached to the LCD screen.
Flip camera so the front is facing you.
Locate speaker in upper right hand corner.
Gently lift with tweasers.
Feed wiring through designated spot so that it is no longer connected to the camera.
Lift the LCD screen so the thick yellow wiring is the only thing attaching the LCD screen to the camera.
Gently pull the thick yellow wiring out by using the forefinger and thumb.
