Olympus D590 Backplate Replacement
  1. Olympus D590 Backplate Replacement, Face Plate: step 1, image 1 of 1
    • Remove five baseplate screws using a Phillips #00 screwdriver.
  2. Olympus D590 Backplate Replacement: step 2, image 1 of 1
    • Press and slide the battery cover retainer clip to the left. Use tweezers to lift the battery cover away.
  3. Olympus D590 Backplate Replacement: step 3, image 1 of 1
    • Remove the single screw from the battery housing using a Phillips #00 screwdriver.
  4. Olympus D590 Backplate Replacement: step 4, image 1 of 1
    • Using tweezers, lift the rubber plate to expose the ports.
  5. Olympus D590 Backplate Replacement: step 5, image 1 of 1
    • Remove two screws from the ports using a Phillips #00 screwdriver.
  6. Olympus D590 Backplate Replacement: step 6, image 1 of 1
    • Use a spudger to pry the faceplate away from the rest of the camera.
  7. Olympus D590 Backplate Replacement: step 7, image 1 of 1
    • To avoid disconnection of the connector line to the motherboard, use caution when pulling faceplate away from camera case.
    • Damage to the connector line will prevent the on/off power switch's operational function.
  8. Olympus D590 Backplate Replacement, Backplate: step 8, image 1 of 1
    • Use a phillips head screwdriver to remove the 3 screws highlighted in the picture.
  9. Olympus D590 Backplate Replacement: step 9, image 1 of 1
    • Unscrew the 2 screws located on either side of the flash.
  10. Olympus D590 Backplate Replacement: step 10, image 1 of 1
    • Get a flathead screwdriver or an iPod opening tool (both are shown in this picture).
    • Carefully pry off the blackplate from the remaining part of the camera.
  11. Olympus D590 Backplate Replacement: step 11, image 1 of 1
    • Pull the backplate off.
Katie
31 Reputation
3 Guides authored
Cal Poly, Team 28-23, Regan Spring 2010 Member of Cal Poly, Team 28-23, Regan Spring 2010
CPSU-REGAN-S10S28G23
4 Members
14 Guides authored
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 13
All Time: 2,046
