Up to 20% off select tools
Oil Drainage
View statistics:
Past 24 Hours:
0
Past 7 Days:
8
Past 30 Days:
13
All Time:
143
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 2 - 5 minutes
Difficulty: Easy
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Oil Drainage
Introduction
Go to step 1 ↓
Prereq guide on draining the oil from a Honda EB3000CK2A 3000 Watt Generator in preparation for service.
    1. Oil Drainage, Elevate the generator: step 1, image 1 of 1
      • Elevate the generator on a set of stable risers, like wooden blocks.
      • Place a drain pan underneath the generator, between the blocks.
      Ask FixBot
    2. Oil Drainage, Drain the oil: step 2, image 1 of 3 Oil Drainage, Drain the oil: step 2, image 2 of 3 Oil Drainage, Drain the oil: step 2, image 3 of 3
      • Use a 12 mm socket to remove the oil drain plugs from either side of the generator.
      • Give the oil a few minutes to drain from the cylinder and crankcase housing.
      • Tip the generator back and forth towards either drain hole to allow any last bits of oil to drain.
      • Once the oil is finished draining, replace the drain plugs.
      • Tighten the drain plugs to 13 ft-lb (18 N-m) of torque.
      • During reassembly, be sure to refill the engine oil:
      • Use up to 0.58 liters of SAE 10W-30 oil, until the dipstick is almost completely submerged.
      Ask FixBot
Author
with
Tarun Thiruma
41,054 Reputation
133 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 13
All Time: 143
