Ohmeda Engström Compressor Replacement
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
    1. Ohmeda Engström Compressor Replacement, Compressor: step 1, image 1 of 1
      • Ensure the device is powered off and unplugged
      • Disconnect any wires or components that are plugged in prior to repair
      Ask FixBot
    2. Ohmeda Engström Compressor Replacement: step 2, image 1 of 1
      • Tap the back end of a flat head screwdriver with a hammer to wedge the side trim pieces away from the machine.
      Ask FixBot
    3. Ohmeda Engström Compressor Replacement: step 3, image 1 of 1
      • Use the flat head screwdriver to pry off and remove the side panels
      • When prying off the panels, do so carefully so that you do not to scratch or damage them
      • When reassembling the side panels, make sure that the connectors snap back into place.
      • Remove the mounting hardware from the compressor on the cart
      Ask FixBot
    4. Ohmeda Engström Compressor Replacement: step 4, image 1 of 1
      • Screw in the service tool to assist in lifting the compressor and sliding out of the cart
      Ask FixBot
Kobe Hayashi
269 Reputation
1 Guide authored
Cal Poly, Team S7-G6, Paton Spring 2020 Member of Cal Poly, Team S7-G6, Paton Spring 2020
CPSU-PATON-S20S7G6
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 54
All Time: 462
