Oculus Rift Development Kit 2 Cable Hub Replacement
  1. Oculus Rift Development Kit 2 Cable Hub Replacement, Cable Hub: step 1, image 1 of 1
    • Using the plastic opening tools, pry open the cable hub.
  2. Oculus Rift Development Kit 2 Cable Hub Replacement: step 2, image 1 of 1
    • Carefully pry the cable away from the cable hub motherboard. It is attached with hot glue and should be removed easily.
    • Note that the cable is soldered on to the board. When prying the cable away from the hot glue, pull gently so as not to damage the soldered wire.
  3. Oculus Rift Development Kit 2 Cable Hub Replacement: step 3, image 1 of 1
    • Desolder the wires as illustrated. This can be done by heating up the solder connecting the board and the wire. When the solder is liquified, pull the wire away from the board.
    • Need some help? Follow this guide to learn soldering basics.
Alexandra Zaragoza
331 Reputation
1 Guide authored
Cal Poly, Team 18-5, Maness Winter 2015 Member of Cal Poly, Team 18-5, Maness Winter 2015
CPSU-MANESS-W15S18G5
4 Members
6 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 2,356
