Oculus Rift DK1 Control Box Bottom Cover Replacement
  1. Oculus Rift DK1 Control Box Bottom Cover Replacement, Control Box Bottom Cover: step 1, image 1 of 3 Oculus Rift DK1 Control Box Bottom Cover Replacement, Control Box Bottom Cover: step 1, image 2 of 3 Oculus Rift DK1 Control Box Bottom Cover Replacement, Control Box Bottom Cover: step 1, image 3 of 3
    • Use a plastic opening tool to carefully pry off the four rubber feet from the control box.
    • You have now revealed the four 9 mm Phillips #1 screws underneath the rubber feet.
  2. Oculus Rift DK1 Control Box Bottom Cover Replacement: step 2, image 1 of 3 Oculus Rift DK1 Control Box Bottom Cover Replacement: step 2, image 2 of 3 Oculus Rift DK1 Control Box Bottom Cover Replacement: step 2, image 3 of 3
    • Use a Phillips #1 Screwdriver to unscrew the four 9mm Phillips screws on the bottom of the control box.
    • You can now remove the bottom lid of the control box. It should come apart easily.
Audrey Chan
201 Reputation
2 Guides authored
Cal Poly, Team 70-5, Forte Winter 2015 Member of Cal Poly, Team 70-5, Forte Winter 2015
CPSU-FORTE-W15S70G5
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 11
All Time: 425
