Oculus Quest 2 Disassembly
    1. Oculus Quest 2 Disassembly, Unscrew the rear cover: step 1, image 1 of 1
      • Start by removing the six T2 screws that hold the inner lining of the headset to the front.
      Ask FixBot
    2. Oculus Quest 2 Disassembly, Remove the rear cover: step 2, image 1 of 2 Oculus Quest 2 Disassembly, Remove the rear cover: step 2, image 2 of 2
      • One side at a time, insert a pick next to the nosepiece, slide it to the edge and pry.
      • When both sides are loose, carefully lift the cover out, and fold it so that the nose piece is on the outer perimeter of the device, as shown in the second image.
      • The proximity sensor is still connected via a flex cable, so be careful to not rip or crease the cable.
      • Lift the small black clip on the ZIF connecter up, and pull the flex cable out.
      • The cable is lightly adhered to the headset so be careful when removing it.
      • During reassembly, make sure to position the cable correctly. Latching the small black clip back on shouldn't require much force. If you don't connect the cable correctly, the headset's screen may stay black and the device will turn off after a few seconds.
      Ask FixBot
    3. Oculus Quest 2 Disassembly, Detach ZIF Connector: step 3, image 1 of 3 Oculus Quest 2 Disassembly, Detach ZIF Connector: step 3, image 2 of 3 Oculus Quest 2 Disassembly, Detach ZIF Connector: step 3, image 3 of 3
      • The ribbon cable is lightly attached to the headset with adhesive and the cable is connected with a ZIF connector. Consult Step 1 of the Recognizing & Disconnecting Cable Connectors guide (RDCC guide) for ZIF connector info.
      • Use the tip of a spudger to flip up the locking flap to release the cable. See pictures 2 and 3 to understand how the flap operates.
      Ask FixBot
    4. Oculus Quest 2 Disassembly, Unscrew the front cover: step 4, image 1 of 1
      • Remove the three P000 screws.
      • Remove the two P000 screws
      • The two orange screws near the top are very deep, a longer head screwdriver may be required
      Ask FixBot
    5. Oculus Quest 2 Disassembly, Remove the front cover: step 5, image 1 of 2 Oculus Quest 2 Disassembly, Remove the front cover: step 5, image 2 of 2
      • Insert a pick and pry at these four spots to release the clips.
      • Lift the front cover away from the headset.
      Ask FixBot
    6. Oculus Quest 2 Disassembly, Remove the battery bracket: step 6, image 1 of 1
      Tool used on this step:
      Buy
      • Unplug the side WiFi antenna. See step 5 of the RDCC guide. To disconnect the cable, slide a thin, ESD-safe pry tool or tweezers under the metal neck of the connector and lift straight up from the board.
      • Remove the 4.4 mm P000 screw
      • Remove the two 2.3 mm P000 screws
      Ask FixBot
    7. Oculus Quest 2 Disassembly, Unplug the battery: step 7, image 1 of 2 Oculus Quest 2 Disassembly, Unplug the battery: step 7, image 2 of 2
      • Unplug the battery. See Step 4 of the RDCC Guide. Use the spudger to pry the connector straight up.
      • Remember to put part of the battery ribbon cable under the logic board when reassembling.
      Ask FixBot
    8. Oculus Quest 2 Disassembly, Remove the Bluetooth antenna: step 8, image 1 of 3 Oculus Quest 2 Disassembly, Remove the Bluetooth antenna: step 8, image 2 of 3 Oculus Quest 2 Disassembly, Remove the Bluetooth antenna: step 8, image 3 of 3
      • Remove two P000, 4.8 mm long screws.
      • Remove four P000, 4.8 mm long screws.
      • Remove two P000, 10.7 mm long screws.
      • The arrow points to the Bluetooth antenna. To disconnect see step 5 of the Guide. Go to picture 2. To disconnect the cable, slide a thin, ESD-safe pry tool or tweezers under the metal neck of the connector and lift straight up from the board.
      • Picture 3. Remove the antenna from the headset.
      Ask FixBot
    9. Oculus Quest 2 Disassembly, Remove the cooling fan: step 9, image 1 of 3 Oculus Quest 2 Disassembly, Remove the cooling fan: step 9, image 2 of 3 Oculus Quest 2 Disassembly, Remove the cooling fan: step 9, image 3 of 3
      • Unplug the fan.
      • Remove the T2 screw
      • Remove the P000 screw
      • Lift the front LED away from the headset.
      • Lift the fan away from the headset.
      Ask FixBot
    10. Oculus Quest 2 Disassembly, Remove the heatsink: step 10, image 1 of 1
      • Remove the four P000 screws
      • Remove the heatsink.
      Ask FixBot
    11. Oculus Quest 2 Disassembly, Disconnect ZIF, WiFi and USB cables: step 11, image 1 of 3 Oculus Quest 2 Disassembly, Disconnect ZIF, WiFi and USB cables: step 11, image 2 of 3 Oculus Quest 2 Disassembly, Disconnect ZIF, WiFi and USB cables: step 11, image 3 of 3
      • There are 2 ZIF connectors near the top of the mainboard. The ZIF flap on the right has been opened. The ZIF flap is opened by pushing down in the direction of the orange arrow.
      • Unlatch both ZIF connectors and disconnect the cables. These cables lead to the front LED and IPD sensor, and proximity sensor.
      • Unplug the side WiFi antenna connector. See step 5 of the RDCC guide. To disconnect the cable, slide a thin, ESD-safe pry tool or tweezers under the metal neck of the connector and lift straight up from the board.
      • Unplug the cable leading to the USB Type-C port and headphone jack. See Step 4 of the RDCC Guide. Use the spudger to pry the press connector straight up.
      Ask FixBot
    12. Oculus Quest 2 Disassembly, Disconnect Speakers from Main Board: step 12, image 1 of 3 Oculus Quest 2 Disassembly, Disconnect Speakers from Main Board: step 12, image 2 of 3 Oculus Quest 2 Disassembly, Disconnect Speakers from Main Board: step 12, image 3 of 3
      • Two sets of speaker cables are connected to the main board.
      • Grab the wires and pull out to disconnect the speaker cables.
      Ask FixBot
    13. Oculus Quest 2 Disassembly, Disconnect Top Cameras: step 13, image 1 of 3 Oculus Quest 2 Disassembly, Disconnect Top Cameras: step 13, image 2 of 3 Oculus Quest 2 Disassembly, Disconnect Top Cameras: step 13, image 3 of 3
      • Disconnect the ZIF connectors for the top cameras
      • The ZIF connector is shown in the second picture. A spudger should be used to push up the locking flap as shown by the red arrow.
      • When the flap is open the ribbon cable may be pulled from the connector.
      • Remember to do both camera ZIF connectors.
      • When reassembling, note that the camera covers are unique to each side. The holes in the covers should be pointed up and in the proper location.
      Ask FixBot
    14. Oculus Quest 2 Disassembly, Disconnect Bottom Cameras & Power: step 14, image 1 of 2 Oculus Quest 2 Disassembly, Disconnect Bottom Cameras & Power: step 14, image 2 of 2
      • Open the flaps on the three ZIF connectors and detach the ribbon cables.
      Ask FixBot
    15. Oculus Quest 2 Disassembly, Disconnect the Screen Cable: step 15, image 1 of 2 Oculus Quest 2 Disassembly, Disconnect the Screen Cable: step 15, image 2 of 2
      • The screen cable is attached with a press connector.
      • Use the spudger to pry the press connector straight up. See Step 4 of the RDCC Guide.
      Ask FixBot
    16. Oculus Quest 2 Disassembly, Remove the mainboard: step 16, image 1 of 1
      • Remove the following screws:
      • One 3.5mm hex screw
      • Four P000 screws
      • These screws are non-magnetic.
      • Remove the mainboard.
      Ask FixBot
    17. Oculus Quest 2 Disassembly, Mainboard: step 17, image 1 of 2 Oculus Quest 2 Disassembly, Mainboard: step 17, image 2 of 2
      • Close up on the mainboard.
      Ask FixBot
    18. Oculus Quest 2 Disassembly, Disconnect the Power to the Midframe: step 18, image 1 of 3 Oculus Quest 2 Disassembly, Disconnect the Power to the Midframe: step 18, image 2 of 3 Oculus Quest 2 Disassembly, Disconnect the Power to the Midframe: step 18, image 3 of 3
      • Unroute the side WiFi antenna.
      • The battery power comes to the midframe through this cable. The cable has a metal pad on the bottom and is attached to the midframe with glue. Separate the metal plate on the bottom of the connector from the midframe.
      Ask FixBot
    19. Oculus Quest 2 Disassembly, Remove the Midframe: step 19, image 1 of 1
      • The midframe is removed giving access to the battery.
      Ask FixBot
    20. Oculus Quest 2 Disassembly, Battery Removal: step 20, image 1 of 2 Oculus Quest 2 Disassembly, Battery Removal: step 20, image 2 of 2
      • Remove the two P000 screws, which hold the battery to the front of the case.
      • Remove the four P000, which hold the battery to the back of the case.
      Ask FixBot
    21. Oculus Quest 2 Disassembly, Battery Case: step 21, image 1 of 2 Oculus Quest 2 Disassembly, Battery Case: step 21, image 2 of 2
      • Remove the three T2 screws, which hold the cover on the battery case.
      • After the cover is removed.
      • The Quest 2 has a battery life of 2.5 hours, drawing an average of 5.6W.
      Ask FixBot
    22. Oculus Quest 2 Disassembly, Remove the USB/Speakers/Arms: step 22, image 1 of 3 Oculus Quest 2 Disassembly, Remove the USB/Speakers/Arms: step 22, image 2 of 3 Oculus Quest 2 Disassembly, Remove the USB/Speakers/Arms: step 22, image 3 of 3
      • Release the speaker wire from the speaker retainer.
      • Remove the seven P000 screws from the speaker retainer and USB port.
      • Use the spudger to free the speaker retainer.
      • Remove the USB charge port and the speaker retainer.
      Ask FixBot
    23. Oculus Quest 2 Disassembly, Removing the Springs: step 23, image 1 of 2 Oculus Quest 2 Disassembly, Removing the Springs: step 23, image 2 of 2
      • Use a small screwdriver to tip up the tabs on the springs.
      • Remove the springs using needle nose pliers.
      Ask FixBot
    24. Oculus Quest 2 Disassembly, Arm Speaker Attachment Method: step 24, image 1 of 3 Oculus Quest 2 Disassembly, Arm Speaker Attachment Method: step 24, image 2 of 3 Oculus Quest 2 Disassembly, Arm Speaker Attachment Method: step 24, image 3 of 3
      • The arm and speaker are passed through the headset and locked in place with the rubber retaining ring.
      • Tabs in the rubber retaining ring pass through the slots in the arm. These are the slots that previously held the springs. the ring is turned to lock or unlock the arm.
      Ask FixBot
    25. Oculus Quest 2 Disassembly, Arm / Speaker Removal: step 25, image 1 of 3 Oculus Quest 2 Disassembly, Arm / Speaker Removal: step 25, image 2 of 3 Oculus Quest 2 Disassembly, Arm / Speaker Removal: step 25, image 3 of 3
      • How you grasp the retaining ring depends on which arm you are working on.
      • When you are working on the arm located near the on/off button, you must put your hand through the part of the headset that is normally towards your face to grasp the retaining ring. You then push the arm down in the direction shown in the second picture.
      • When working on the arm located near the USB port you must put your hand through the front of the headset to grasp the retaining ring. You then push the arm down as shown in the third picture.
      Ask FixBot
    26. Oculus Quest 2 Disassembly, Lens assembly: step 26, image 1 of 3 Oculus Quest 2 Disassembly, Lens assembly: step 26, image 2 of 3 Oculus Quest 2 Disassembly, Lens assembly: step 26, image 3 of 3
      • Small metal tabs hold the guide rails that the lenses slide on. Removing the rails reveals the display.
      • There is a protective sheet of plastic over the screen. Be careful of dust and scratches.
      Ask FixBot
Finish Line
144 other people completed this guide.
sctanf
2,576 Reputation
1 Guide authored
90 Guide Comments
Thank you so much to me for making this guide. Helped me a lot!
It is worth emphasizing that this device has 2! WIFI antennas.
Anyone who wants to disconnect WIFI from their device must disconnect both.
Their connection to the motherboard, is right next to each other, but the right connection is immediately revealed while the left connection next to it is hidden under the black cover and requires a number of additional disassembly steps.
Alternatively, anyone who wants to disconnect WIFI from their device can disconnect the wires in the area where they connect to the antenna stickers on the right and left sides of the eyepieces of the glasses, thus saving all the disassembly of the front cover.
שמחה גרשון בורר - Reply Share
Thanks!! this really helped me, I have already customized mine with an official custom filter, but this will add an additional layer of Kashrus.
Leib Felberbaum - Reply Share
If you just need to replace a camera… it’s 14 screws. You need a T2 and a PH0 (not a P0…) Pretty easy once you get the front cover off and not covered here. It’s pretty easy to see what you do once you get in there though. Good luck!
Chris Madson - Reply Share
PH0 and P0 are the same :)
Lylo - Reply Share
Bravo pour ces informations. Un grand merci
Guidemann Christophe - Reply Share
Past 24 Hours: 81
Past 7 Days: 485
Past 30 Days: 2,306
All Time: 322,978
